Understanding Momentum: Solving Problems with the FT=MV Formula
  • Thread starter Thread starter Zuloft
    Momentum
The discussion focuses on solving three physics problems using the momentum formula FT=MV, specifically confirming the correct application of the formula. The first problem involves calculating the force of impact when a football player collides and comes to rest. The second problem requires determining the contact time of a golf club with a ball given the force applied and the ball's mass. The third problem asks for the force needed to change a baseball's velocity in a specific direction. Participants confirm that using the formula F=ΔP/Δt is appropriate for all problems, as it relates momentum change to force.
Zuloft
i have 3 problems for homework and I am stomped. i don't know if the way I am solving the problem is right. I am using the FT=MV forumla for all 3 problems.
1) a football player of mass 120 kg is traveling at 20 m/s collides with another player and comes to rest in 1.5 s. what is the force of impact?
2) a golf ball of mass 0.050 kg acqyuires a speed of 80 m/s when hit with a force of 3.0 x 10 ^3 n. how long was the club in contact with the ball
3) what force acting for 1.36 x 10 ^-3 will change the velocity of a 95 g baseball from 50.0 m/s east to 45 m/s west?
thanks!? but i just need confirmation on what formula to use.
just to clarify when you say FT=MV you do mean Ft=M\Delta V?
correct i couldn't find the delta symbol
Yeah, using F=\frac{\Delta P}{\Delta t} will work for all three.
https://www.physicsforums.com/latex_images/88/884080-0.png
can i use that though?
There isn't any difference between them, other than algebra manipulatioon. \Delta P = m \Delta v since mv is the definition of momentum, and mass is a constant.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
