Momentum Head on Collision Cart Problem
The discussion revolves around calculating the kinetic energy lost during a head-on collision between two remote control cars. The initial momentum of the system is calculated using the masses and velocities of both cars. The conservation of momentum is applied to find the final velocity of the more massive car after the collision. The initial and final kinetic energies are computed using the formula for kinetic energy, and the difference between them gives the kinetic energy lost. Ultimately, the approach emphasizes using conservation principles to derive the necessary values for the calculation.
bleedblue1234
Two remote control cars with masses of 1.11 kilograms and 1.81 kilograms travel toward each other at speeds of 8.75 meters per second and 3.39 meters per second, respectively. The cars collide head-on, and the less massive car recoils with a speed of 2.99 meters per second. How much kinetic energy was lost in the collision?
no idea
I don't really understand how to start... I was thinking we could calculate the total momentum of the system then calculate the ideal final velocity of the less massive cart then calculate the difference?
Would you fine the total momentum of the system... thus (1.11 kg)(8.75 m)+(1.81 kg)(- 3.39m) = 3.5766 kg * m /s then divide that by 1.11 kg to find the ideal velocity of the smaller cart... or 3.22216ish m/s... then get the kinetic energy of that which will be 1/2(1.11)(3.2216)^2 = 5.762192 J , then find the kinetic energy of the kinetic energy of it actually, or 1/2(1.11)(2.99)^2 = 4.961755 then subtract 5.7621 - 4.9617 = .800 J ?
I think you're on the right track. Use conservation of momentum to find the velocity of the other cart after the collision. The total kinetic energy before the collision can be calculated using (1/2)*m*v^2 for each of the carts. If you do the same after, the kinetic energy will be less. So you're right, subtract.
Ultimately, we are trying to find \DeltaKE which is equal to KEf - KEi.
KEf = KE1,f + KE2,f and KEi = KE1,i + KE2,i
KEf = \frac{1}{2}m1v1,f2 + \frac{1}{2}m2v2,f2 and KEi = \frac{1}{2}m1v1,i2 + \frac{1}{2}m2v2,i2
Therefore, \DeltaKE = \frac{1}{2}(m1v1,f2 + m2v2,f2 - m1v1,i2 - m2v2,i2)
Of course, we don't know v2,f, so we have to use conservation of momentum to find it.
Since the law of conservation of momentum tells us that pi = pf and we know p = mv, then it follows that m1v1,i + m2v2,i = m1v1,f + m2v2,f
Solving for v2,f, we get v2,f = ( m1v1,i + m2v2,i - m1v1,f ) / m2
After solving for v2,f, you can substitute that value into the \DeltaKE equation, and that should tell you the amount of KE lost.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
