Momentum Conservation in Collisions - How to Solve for Resulting Velocity
  • Thread starter Thread starter ilovephysics07
    Momentum Physics
To solve the physics problem of two trucks colliding and sticking together, first calculate the masses of both trucks using their weights divided by gravity. Next, apply the conservation of momentum principle, which states that the total momentum before the collision equals the total momentum after the collision. Since this is a two-dimensional problem, momentum must be calculated separately for both the x and y components. After determining the momentum vectors for each truck, sum them to find the total momentum of the combined mass. Finally, divide this total momentum by the combined mass to find the resulting velocity of the trucks post-collision.
ilovephysics07
I'm confused on how to start this Physics problem. Please help me and go through the steps with me.
Thank you.
Two trucks collide. One weighed 1500 Newton and was traveling 45.0 m/s at 105 degrees. The second weighed 1800 Newton and was traveling 27.5 m/s at 55 degrees. Find the resulting velocity of the trucks if they stuck together on impact
Ok so the first step i did was get the mass which is the force (1500) divided by 9.8 m/s^2 and got 150 kg and did the same to truck #2 and got 180 kg.
Because i know we have to use the mass to find the momentum which is force time velocity.
However after that step what i do?
The setup will be one of a completely inelastic collision:$$m_{1}v_{1} + m_{2}v_{2} = (m_{1} + m_{2}) v$$This means that the sum of the individual momenta will equal the momentum of the combined masses. However, since this problem is in two dimensions, you need to use the equation twice: once for the x-components of velocity, and again for the y-components.
Hello lover and welcome to PF. A special welcome, I might add, because the nickname fills us with (false?) pride.
Somehow you managed to evade the template. But your rendering of these toy trucks smacking into one another gives me the impression you've seen it come by. Please use it next time.
Now to business: One of the relevant equations would be F = mg which you used to calculate the m. Decently written exercise: weight as a force. We like that.
Another would be conservation of momentum. You should have learned that momentum is conserved in accidents like this. Momentum is not force times velocity, but mass times velocity. masses you have, velocities you have also. Note that velocities are vectors: they have a magnitude (given) and a direction (also given). All you have to do is add these momentum vectors to get the momentum vector of the stuck-together wreckage, of which you can easily calculate the mass. Divide by mass and voila: the velocity vector !
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
