More Simple Harmonic Oscillations
An object in simple harmonic motion with a period of 4.00 s and an amplitude of 9.08 cm is analyzed for its movement from x=0.00 cm to x=5.07 cm, but the initial calculations yield an incorrect time of 0.623 s. To solve this, the phase constant must be determined using the equation x(t)=Acos(ωt + φ), starting with a sine function for the initial condition. Additionally, the angular frequency should be expressed in radians per second, not degrees. A similar approach applies to finding the first time when the velocity is -0.120 m/s, indicating that mastering the phase constant is crucial for both problems. Clear understanding of these concepts is essential for accurate solutions in simple harmonic motion.
ubbaken
An object in simple harmonic motion oscillates with a period of 4.00 s and an amplitude of 9.08 cm. How long does the object take to move from x=0.00 cm to x=5.07 cm?
I set up my eqn like this: 0.0908cos(ωt)=0.0507
cos(ωt)=0.583
ωt=56.1
then with ω=90deg I get 0.623s which is slightly higher than I think the answer would be, and is ultimately incorrect.
I've tried working the problem out a number of times, in rad and degs to make sure I'm not making an error there, and I get the same answer.
The velocity of an object in simple harmonic motion is given by v(t)= -(0.250 m/s)sin(17.0t + 1.00π), where t is in seconds. What is the first time after t=0.00 s at which the velocity is -0.120 m/s?
for this one it seems like I just have to work it through to find t. When I do so, I get down to 17.0t+1.00π=28.7 (from using sin^-1=-.120/-.250) and then there is no answer that fits (0<t<5 approx.). Plus, in trying the answers, they are wrong.
also, I have another problem I posted about https://www.physicsforums.com/showthread.php?t=142893"
I'm pretty spent on these, any and all help would be appreciated.
You have two condtions x(0)=0, and x(t)=5.07cm. To use the equation that x(t)=Acos(\omega t + \phi) you have to first find the phase constant. So you need to make a statement like
x(t)=Acos(\omega t + \phi)=0
It is pretty obvious for this one because you essentially want to just start with a sine function. But you can solve and find the phase. Then you want to use that phase you found to solve when x(t)=Acos(\omega t + \phi)=5.07cm. Another problem I see with what you did is you are saying the angular frequency has units of degrees? Remember that \omega = \frac{2 \pi}{T} where T is the period, and has units of s^-1.
The second one is very similar, if you can get the first one then you can get the second one.
