What is the purpose of using two cylinders in a Moriya Stirling engine fan?
The Moriya Stirling engine fan utilizes two separate cylinders for the power piston and the displacer piston, enhancing efficiency by allowing independent movement. Unlike some designs where the cylinders are connected, the Moriya design features a drilled passage in the base that links the two cylinders internally, which is not visible externally. This design choice helps optimize the engine's performance while maintaining a compact structure. Users have reported successful builds and operation of the engine, indicating its viability as a project. Overall, the Moriya Stirling engine fan represents an interesting engineering challenge and a functional design.
hihiip201
The design in that link *does* have two cylinders -- one for the power piston and one for the displacer piston.
But in the moriya design, there are two different cylinders that are not connected. (power and displacer are separated.
Here the two "cylinders" are connected in the link.
hihiip201 said:
But in the moriya design, there are two different cylinders that are not connected. (power and displacer are separated...
In the Moriya design there is a drilled passage in the base, that connects the two cylinders. You can't see this from the outside. The outer end of the passage (where the drill went in) is closed off with a threaded plug. Depending on how the engine is mounted, the legs may cover up this plug so you would not see it.
I built one of these as a school project (35 years ago!) following the plans in Live Steam magazine (December 1974 thru February 1975). The engine still runs fine.
Good luck, it is a fun project.
Likes 1 person
I see! thanks!
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
