Calculating Velocity in Two Dimensions: A Real-Life Swimming Challenge
The swimmer's velocity was calculated as 3.63 m/s at a direction of N 30 degrees E, considering her initial velocity of 4 m/s north and the cross-current of 2 m/s at 25 degrees south of east. The problem was approached by breaking the velocities into components and using trigonometric functions to resolve the vectors. The calculations involved creating a triangle to visualize the velocities and applying the Pythagorean theorem to find the resultant speed. The final direction was determined using the tangent function. Overall, the calculations appear to be correct based on the provided methodology.
Mary1910
Question:
In an anniversary celebration of Marilyn Bell's 1954 feat- she was the first person to swim across Lake Ontario- a swimmer set out from the shores of New York and maintained a velocity of 4m/s (N). As the swimmer approached the Ontario shore, she encountered a cross-current of 2 m/s (E 25 degrees S) - 25 degrees South of East. Calculate her velocity with respect to the crowd observing from the beach (with respect to the ground).
My Attempt at a Solution:
First I drew a triangle. 4m/s (N) is the left side of the triangle. 2m/s (E 25 degrees S) is the top of the triangle. And the right side is the side that I think that I am solving for.
Next I divided the triangle into two right angled triangles.
Solving for the top triangle:
sin=Opposite/Hypotenuse
=2sin(65)
=1.81 m/s
cos=Adjacent/Hypotenuse
=2cos(65)
=0.845 m/s
=0.85m/s
To solve for the bottom triangle:
4m/s - 0.85m/s = 3.15m/s
Use Pythagorean theorem to solve for the unknown side:
3.15^2 + 1.81^2
=3.63m/s
Calculate the direction of the velocity:
tan=ay/ax
tan=1.81/3.15
=29.88
=30 degrees
Therefore her velocity, with respect to the crowd observing from the beach is 3.63m/s (N 30 degrees E)
Could someone please let me know if my calculations are correct? I would appreciate the help. :)
Looks right to me.
Likes Mary1910
