Motion of a Proton in Electric and Magnetic Fields
The discussion centers on the motion of a proton in electric and magnetic fields, specifically calculations involving kinetic energy, speed, and radius of curvature. The kinetic energy of a proton accelerated through 248 kV is calculated as 3.97 × 10-14 J. The speed of the proton is derived using the formula v = √(2K/m), leading to a corrected value of approximately 1.68731 × 1012 m/s. Additionally, the radius of curvature is calculated using r = mv/(qB), with the mass of the proton correctly identified as 1.67 × 10-27 kg. The discussion emphasizes the importance of using accurate units and values in calculations.
  • Understanding of kinetic energy calculations in physics
  • Familiarity with the conversion of electron volts (eV) to joules (J)
  • Knowledge of the mass and charge of a proton
  • Proficiency in using formulas for motion in electric and magnetic fields
  • Learn about the Lorentz force and its impact on charged particles in magnetic fields
  • Study the principles of particle acceleration and energy conversion
  • Explore the use of LaTeX for formatting scientific equations
  • Investigate the implications of relativistic effects on particle speeds approaching the speed of light
Students and professionals in physics, particularly those focusing on electromagnetism, particle physics, and engineering applications involving charged particles.
Variable_X
A proton is accelerated through a voltage of 248 kV.
a) Calculate the energy of the proton in electron volt and in Joule.
b) Assuming that the mass of the proton remains the same as its rest mass, calculate the speed of the photon.
c)The proton is curved by a magnetic field of 1.5 Telsa. Calculate the radius of the curvature of its path.
N/A
a) 248*10^3 eV for 248kV
Calculate the energy in J
K=248*10^3*1.6*10^-19
=396.8*10^-19 J
b)
K=(1/2)mv^2
v=sqrt(2k/m)
=sqrt((2*396.8*10^-19)/1.67*10^-27)
=218^10^3 m/s
c)
r=mv/qB
=1.67*10^-27*218*10^3/1.6*10^-19*1.5*10^-4
=15.17 mr=mv/qB
=15.17 m
You lost a factor 103 in the kinetic energy calculation.
Your magnetic field has a strange factor 10-4.
Generally:
Don't leave out units, they are important.
a/b*c could be read as ##\frac a b \cdot c##. Put brackets around denominators: a/(b*c) is unambiguous.
Even better: Use LaTeX for formulas.
Also these are PROTON calculations not PHOTON calculations!
Or actually earlier in the conversion to Joules.
Which would have been much easier to pinpoint and troubleshoot if you solved the problem symbolically before substituting numerical values.
Variable_X said:
Re-workings
a)
converting 248kV to eV gives me $$2.4 × 10^-13$$
What sort of calculator are you using?
You know that if you search online for "electron volts to joules" you can find something to do the calculation. You just type in the number.
I not changing eV to Joules at that point I'm changing kV to eV
And how are you doing that?
Variable_X said:
I guess I've done it wrong... E(eV) = V(V) × Q(e) so changing 248kV to V = 248000
248000x1.60x10^-19= 3.968x10^-14
An ##eV## is the energy an electron (or proton or anything else with the same charge) gains when accelerated through ##1V##. I thought you got this right in your OP:
Variable_X said:
Ok so what about the rest?
I may be mistaken, but I think everything else is wrong.
  • Sad
Let's see where we are. First, we can write down the kinetic energy in ##eV##: ##T = 248keV##.
Next, we use a calculator (or the Internet), to convert that to Joules: ##T = 3.97 \times 10^{-14}J##.
Now, we need the speed of the proton. How would you do that?
Yeah, I understand now, it's 6.9x10^20ms-1 (rouned)
Variable_X said:
Yeah, I understand now, it's 6.9x10^20J (rouned)
What is that?
That's worse! What's the speed of light?
3.00x10^8 ms-1
Variable_X said:
3.00x10^8 ms-1
And the speed of your proton?
  • Skeptical
I'm signing off now. But, really, you can't produce a nonsensical answer like this and not realize your calculation has gone awry.
I believe you know what you are doing. Your original post does the right things for the right reasons using the right equations. (Except you converted the magnetic field to Gauss for some reason. Tesla is already the SI unit). You just can’t seem to do the numerical calculations correctly. I don’t know if you type in things wrong or don’t use scientific notation correctly, but all your difficulties arise from your calculator skills.
You should try again. I think you’ve seen and understood that your energy in Joules was off by a factor of 1000. Since the speed is proportional to the square root of energy, the speed is off by a factor of about 33. Since you converted to Gauss when you should have used Tesla your radius is off by an additional factor of 10^4. So you should have a very good idea of what the correct answer is. If you get something wildly different, you are once again making a calculator error.
Right so
a) is 248keV.
3.97×10−14JT=3.97×10−14J.
b) v = √(2K/m) should be √(2(3.97x10^-14)/1.67×10-31) = 6.89528x10^9 ms^-1
I'm assuming the question has typos and it's meant to be for the speed of the PROTON, not the PHOTON.
c) r = mv/(eB) r=1.67×10-31x6.9x10^9/(1.67×10-19x1.5) = 0.0046 nm
See #17 and #18 and consider if these values are realistic.
You seem to make many errors with the calculator, that makes it even more important to check if the answer is plausible.
Variable_X said:
Right so
You still have ##v > c##! Where did you get the mass of a proton?
you're using the mass of an electron and not of a proton at both b and c
Actually, it's neither one thing nor the other:
Mass of proton: ##1.67 \times 10^{-27}kg##
Mass of electron: ##9.11 \times 10^{-31}kg##
Mass used in this problem: ##1.67 \times 10^{-31}kg##
Variable_X said:
My rest Mass of a proton is given as 1.67×10^-31 kg
Your protons must be different from all the others! That's less than an electron. Please check online.
Variable_X said:
a) is 248keV.
b) v = √(2K/m) should be √(2x3.97x10^-14)/1.67×10^-19) = 1.68731x10^12 ms^-1
You appear to have used the charge on a proton instead of its mass.
Variable_X said:
a) is 248keV.
b) v = √(2K/m) should be √(2x3.97x10^-14)/1.67×10^-27) = 1.68731x10^20 ms^-1
Don't post any more answers until you get a speed significantly less than the speed of light.
  • Haha
Please don't delete posts, especially not if people replied, this makes the thread difficult to follow.
9K
