Calculating Displacement of Roller Coaster Motion
To calculate the displacement of the roller coaster, the motion must be broken down into x and y components. The initial horizontal movement is 201 ft, with no vertical displacement. The next segment involves a 150 ft rise at a 27.5-degree angle, which adds to both x and y components. The final segment is a 150 ft descent at a 38.2-degree angle below the horizontal, which must be accounted for in the calculations. By using vector addition and the head-to-tail method, the total displacement can be determined from the combined x and y components.
gadawg90
A roller coaster moves 201 ft horizontally, then rises 150 ft at an angle of 27.5o above the horizontal. It then travels 150 ft at an angle of 38.2o below the horizontal. What is the magnitude of its displacement from the starting point at the end of this movement? What is the angle relative to the horizontal of this displacement? Use positive values for angles above and negative values for angles below the horizontal.
I think you ahve to split this up into its x and y components? help would be awesome.
Yes! Figure out the total horizontal displacement & total vertical displacement. Then the answer will come easily.
right i understand i need to find those, but can someone start me off in the right direction..
Use the head to tail method of vector addition to make it easier to get at an answer.
So the roller coaster moves 201 ft initially, so that's x=201, y=0. Then it moves 150 ft at an angle of 27.5o above the horizontal, so x=201+150*cos(27.5), y=0+150sin(27.5). Do the same with the rest of the ride.
