Motorcycle physics -- Countersteering and Bodysteering
  • Thread starter Thread starter Erunanethiel
    Motorcycle Physics
The discussion centers on the physics of motorcycle steering, particularly the concepts of countersteering and bodysteering. It highlights the challenges of countersteering in emergency situations, where riders may tense up and struggle to maneuver effectively. Bodysteering is presented as a viable alternative, allowing riders to shift their weight to initiate turns without relying solely on handlebars. The conversation also touches on the implications of motorcycle design, specifically regarding trail geometry and its impact on steering dynamics. Ultimately, the thread emphasizes the importance of understanding weight distribution and body movement in motorcycle handling.
Erunanethiel
I didn't want to delete or edit the original thread, since it had a lot of information in it but due to me not being specific enough when asking the question, we got non specific answers. I tried to reach the moderators in the other thread about opening a new thread but could not succeed, hopefully this won't bother them. So here goes:
On a frictionless road and tires, I know the rider wouldn't be able to change the combined center of gravity of the system by moving his weight around. If he pushes the bike to lean to the right, he would go to the left by the amount that would keep the combined cog the same. But a bike with real tires and a real road under it is not a closed system, the tires wouldn't let the lower part of the bike left or right when trying to initiate lean. Does this mean it is possible to push with your bodies inertia to the bike, and the combined cog will be changed?
I think if you do so below the center of mass of the bike, you could, but I am not sure, since the tires will want to move more, but won't be able to, making the combined center of gravity shift more than if you applied the force higher up. And I think you should use horizontal forces on the pegs not up/down forces on the pegsI know counter steering is the best way, but I would like to think it is possible to change direction without it, without the influence of handlebars
Please ignore gyroscopic forces and assume the bike doesn't have any trail geometry (so you would have to "catch" the bike manually through the handlebars)
Thank you very much
Thread closed for Moderation...
Okay, thread will be re-opened (now in the ME forum), with the focus on countersteering and bodysteering a motorcycle. Here is the previous thread for reference:
https://www.physicsforums.com/threads/motorcycle-physics-question.926581/
Next time, please just click the "Report" link on your post to ask for the help of the Mentors/Moderators. :smile:
Yes, as mentioned in your previous thread, using shifted weight on the footpegs and seat will lean the motorcycle over to start a turn.
Countersteering is a pretty reliable way to initiate a turn on a motorcycle, but it has a couple of practical problems that bodysteering addresses.
First, countersteering relies on you being able to use your arms to push-pull the handlebars to move the front tire contact patch to one side to initiate a turn in the other direction. The problem is that in emergency situations on the road, your arms tend to tense up and your ability to countersteer around an obstacle goes way down. That panics you even more, which makes your arms tense up even more, and you can guess what happens next. This is one of the common reasons that new motorcycle riders often fail to make it around a turn or a highway onramp/offramp -- they tense up, straighten up, and ride right off the outside of the turn. Bad news.
The other problem with countersteering is that even if you are very, very good at it (I used to be), it is very hard to have the precise control in a hard turn or turn combination that you would like. I learned bodysteering at Reg Pridmore's CLASS schools, and the first few times I tried to ride down the Corkscrew at Laguna Seca, I kept missing the best fall line, and was wide at entry, or in transition between the two turns, or at exit. It was very frustrating. But I finally started listening to Reg more in the classroom portion of the school, and heard him talking about bodysteering and letting the bike steer itself with the front end once you used your weight shift to start the turn. I started using that through the Corkscrew and the other turns at Laguna Seca, and what a difference! The bike really did just steer itself down the fall line once you used your weight shift to get it turned in the right overall direction at the start of the turns. Amazing.
I don't know if it was covered in your previous thread, but Keith Code (who runs a competing motorcycle racetrack school) has build a "No BS" (no bodysteering) sportbike, where you can take your hands off of the handlebars and still control the throttle, front brake and clutch from a fixed set of bars on the bike. Apparently riding it is pretty scary, since you have lost your normal low-speed control of the bike. I'm guessing that Reg or his son Jason would have no problems riding the No BS bike at speed around tracks, but I haven't asked him about it.
Also, I think you asked about a fixed front fork arrangement in your previous thread. That won't work for steering the bike. In bodysteering, you need the bike's geometry to be able to turn the forks into the turn and track the natural balance through the turn.
Hope that helps. Thread is now re-opened.
BTW, here is the Corkscrew -- one of the most fun places on Earth! :biggrin:
https://image.redbull.com/rbcom/010...oing-through-the-corkscrew-at-laguna-seca.jpg
Likes Erunanethiel
Back on to counter-steering, a videos of a no bs bike. Although some have claimed that Keith Code stated that body-steering doesn't work, Keith only stated that it's not as as fast or effective as direct counter steering as explained in the video. At 1:35 into the first video, the rider has difficulty weight shifting to chang the lean angle to the other side. In my opinion, the rider didn't shift enough of his weight to fully change the lean angle, but on a narrow 2 lane road, couldn't risk experimenting with more radical movement.
Here is a video of the original "no bs" bike. It appears that it was setup (perhaps deliberately) so that it was almost impervious to body-steering. Extreme body shifting only results in mild lean responses from this version of the "no bs" bike. The bike's setup would not noticeably affect it's response to counter-steering. The bike can be seen at 2:15 into this video. At 3:35 into the video, a pointer connected to the handlebars of a normal bike to show the handle bar movement.
Likes Erunanethiel
https://www.physicsforums.com/threads/motorcycle-physics-question.926581/Next time, please just click the "Report" link on your post to ask for the help of the Mentors/Moderators. [emoji2]Yes, as mentioned in your previous thread, using shifted weight on the footpegs and seat will lean the motorcycle over to start a turn.
BTW, here is the Corkscrew -- one of the most fun places on Earth! [emoji3]
How about if you use weight shifting on a bike with no trail in it's geometry?
That was the I meant to ask actually in the first thread when I said "locked steering", I actually meant "no trail" as I actually learned how trail worked.
Does the act of leaning to one side on the motorcycle (and the motorcycle leaning the other way) cause a change of lean angle due to tires resistance due to friction with the road to not let the motorcycle's lower part move, without trail in the bike's geometry?
An easier way to ask the same question is this:
When the rider leans right on the motorcycle with no trail (looking from behind), does the motorcycles lean to the left cancel the rider's movement completely, keeping the combined center of gravity the same? If no, which way would the system fall to, if you didn't "catch" the fall with countersteering "manually"?
And does where and how you apply the force make a difference?
Thank you very much for keeping the thread open, I will do as you say if I ever need to contact moderators or mentors
I don't know what happens with no trail. I do know that the rake and trail of modern sportbikes is virtually the same among different brands, because over the years they have been able to optimize them at the track.
As for the weight shift in bodysteering, you generally have most of your weight on the footpegs during cornering, and to turn in you pull with your inside heel and weight the inside peg and unweight the outside peg. This folds the front end in as the bike and you lean over. You end up leaning more than the bike, with the center of your butt typically along the inside edge of the seat. Stay balanced on the pegs (heavier weight on the inside one).
Likes Erunanethiel
Simplify the situation to the rider only applying a lateral force at some point above the bike's center of mass. The variables are the bikes angular momentum compared to it's mass, how far from the center of mass to the bottom of the tires, and how far from the center of mass to where the rider applies a lateral force to the bike.
Note that the forces between ride and bike are Newton third law pairs. You could consider this as the rider pushing against the bike and the bike pushing against the rider (the rider's leg muscles are pushing in both directions).
How the bike reacts depends on the variables. If absent friction, the bike would "lean" more than it translates, then with friction, the pavement pushes in the same direction as the rider pushes on the bike, and the center of mass of the system moves towards the bike's direction. If absent friction, the bike would "lean" less than it translates, then with friction, the pavement pushes in the same direction as the bike pushes on the rider, and the center of mass of the system moves towards the rider's direction.
Likes Erunanethiel
The amount the bike translates is not inversely correlated to how much it leans though, how much it will translate is always dictated by the impulse, no matter how far away you pushed from the center of mass and how much "spin" or "lean" you initiate. There is a video about it that veritasium tries it, but can't explain it well enough, so I actually got the answer from this forum, which made me sign up here. The answer is that work≠impulse, so even if impulse is the same, you can do more work by pushing off the center off mass so you push for "longer" so that explains where the extra kinetic energy of spin comes from, the impulse is the same so the block reaches the same height vertically
This is the video:
The amount that the center of mass that the bike translates is related to the impulse, but the amount that the contact patches of the tires would translate on a frictionless road would depend on the variables I mentioned in my last post.
Consider a long rod of in space, and an impulse applied to one end of the rod, perpendicular to the rod's orientation. If the rod's angular momentum is low enough (a rod with uniform mass distribution would have low enough angular momentum), then although the rod's center of mass moves in response to the impulse, the other end of the rod initially moves in the opposite direction as the impulse.
Likes Erunanethiel
Is it possible to apply a lateral force to the bike preferably low down on the bike like pegs in order to make the most of the friction stopping the tires move laterally, so the center of mass would shift more to the side the rider leaned in to?
That sounds like what I was describing in post #7, although the pulling force with the inside heel is more to pull your body weight over to add weight to the inside footpeg to fold the bike into the turn. It may do something to push the tire patches to the outside, but I haven't felt that as a primary affect of the pulling motion.
Likes Erunanethiel
The rider would have use his own angular momentum as resistance to any lateral force applied that doesn't go through the riders center of mass.
Consider the scenario where the rider applies a lateral force at the pegs (assuming the pegs are close to or below the bikes center of mass), and zero force at any other point on the bike. This will cause the rider to rotate about the roll axis due to the force that the pegs exert onto the riders feet as part of a Newton third law pair of forces. The pegs are so far below the riders center of mass that the rider could not generate much force, especially compared to the total weight of the bike + rider, but it would result in the force from the pavement be in the opposite direction of the force the rider applied to the pegs.
So for example, the rider exerts a force to the left on the pegs, and the pegs exert a force to the right onto the riders feet. In this case the pavement exerts a force to the right on the tires, so the center of mass of bike and rider move to the right, but the rider is leaning to the left (the "wrong" way).
The rider could exert internal torques on the system of bike and rider by leaning at the waist, or better still by swinging a free leg outwards, which is what trials riders do when stationary, in addition to taking advantage of caster offset with steering inputs and hoping the bike off and on the ground to maintain balance and/or reorient the bike. Trials bikes are relatively light, and leg swinging may not do much for a heavier street bike.
A bike on a tight wire is a good analogy for a bike with locked steering. The tight wire bikes are light, and a long and fairly heavy balance pole is used to generate the torques needed to balance the system.
Likes Erunanethiel
In the previous posts we came to the conclusion that the systems center of mass would shift to the side where the rider leaned in to, and I can't fathom out what is different this time
Previously, I only considered a lateral force close to or below the bikes center of mass. If the lateral force is applied high enough above the bikes center of mass and the bottom of the tires are low enough below the bikes center of mass, then the tires would want to move the other way, and the force from the pavement would be in the opposite direction of the rider's movement relative to the bike.
Likes Erunanethiel
Okay, I see
In the usual case the pegs are likely to be below the center of mass of the bike, I think. In that case;
In order to apply horizontal forces through the pegs, you have to push the other way first right? Or you would end up rotating the opposite way you want to rotate and the bike rotates the other way, from what I understand. Am I correct?
What country/state are you in? Is there beginner motorcycle riding instruction available where you live? It sounds like you would gain a lot by getting out and doing some riding... :smile:
San Jose CMSP training -- https://www.pacificmotorcycletraining.com/
General CMSP California program -- http://2wheelsafety.com/register/
Overall Info -- https://www.msf-usa.org/BRC.aspx
Likes Erunanethiel
What country/state are you in? Is there beginner motorcycle riding instruction available where you live? It sounds like you would gain a lot by getting out and doing some riding... [emoji2]
I do not live in the USA, and I do ride, I have a Ducati 1098 currently.
But the theory of it still confuses me, and I can't try many things in this thread because my bike has trail in it's geometry and very expensive parts that need to be replaced in case of an accident [emoji23]
From my prior posts:
... and the rider leaning the wrong way.
Likes Erunanethiel
That's not what I meant
If I want to lean right (looking from behind) and I applied a force to the left, my body would rotate to the left (and the bike to the right).
So if I want to lean to the right, I need to push a bit to left first, like if you want to move a broom balanced on your hand to the right, you need to move your hand a bit to the left initially, so you can move it to the right without it tipping over
If you apply a left force on the pegs, you end up leaning left and the right force from the pavement moves the center of mass of the system to the right, and the combined force applied to pegs and tires leans the bike left. With the steering locked, I don't know if the tire contact patches end up under the center of mass or offset to one side or the other.
Likes Erunanethiel
If the rider stands up on the pegs and pushes to the left on the pegs, doesn't he lean to the right? Isn't that the case when we walk too?
You can try this while standing on your left foot. If you push to the left, your upper body leans to the left (or you can raise your right leg), and fall to the right until you correct the imbalance.
Likes Erunanethiel
The footpegs are not flat ground. As you unweight your right foot and transfer that weight to your left foot, the bike folds over to the left. Think standing on a short see-saw with your feet straddling the middle fulcrum. If you lift one foot, your body drops down...
Likes Erunanethiel
The OP was asking what happens when you exert a left horizontal force on the pegs, not a downwards force on the left peg, or a differential vertical force on the pegs. The goal here is to exert a left force onto the pegs, and in turn, have the tires exert a left force onto the pavement, so that the pavement exerts a right force onto the tires, in turn causing the center of mass of bike and rider to be accelerated to the right, in a locked steering scenario.
Likes Erunanethiel
I am confused
What is the answer we came up with to the original question?
For the locked steering scenario, if the rider applies a lateral force too high above the center of mass, and the tire contact patches are too far below the center of mass, then the Newton third law pair of forces between tires and pavement are in the "wrong" directions.
If the rider applies a lateral force at the pegs, the Newton third law pair of forces between tires and pavement are in the "right" directions, but the rider ends up leaning the "wrong" way, except if the rider raises a leg to do all of the "leaning". Only a small amount of lateral force can be applied in this manner.
Body leaning or weight shifting to turn requires the indirect counter-steering reaction of the bike when it's initially leaned to the "outside" in response to the rider leaning to the "inside", in order to steer the tires to the "outside" to setup the lean of the system of bike and rider for a turn.
Likes Erunanethiel
  • #31
For the scenario where the trail is absent;
I think applying a force too high above the center of mass is quite hard, because no part of the motorcycle is that high. And I think this is the case where the rider leans the "wrong" way. Because the system will fall to the side the the motorcycle is leaning into not the side where the rider is leaning to, because the tires increase amount of rotation the bike will do in the case of applying a force high up on the bike.In the case of applying horizontal force through the pegs, the rider should be leaning the "right" way. Because tires keep the bike from going the "other way" as much as it would if there was no friction, so the motorcycle's movement can not cancel the riders movement to the other side, thus making the center of mass go to the side rider leaned into and the system falls to that side.I still don't get why we can't apply much horizontal force through the pegs. We can apply large enough forces on a day to day basis to move our bodies around
  • #32
Erunanethiel said:
For the scenario where the trail is absent; I think applying a force too high above the center of mass is quite hard, because no part of the motorcycle is that high.
The handle bars and/or the rider's center of mass (a bit above the seat) are probably high enough to create the issue on some bikes.
The issue is that the pegs apply a force to the rider way below the rider's center of mass. This results in a torque that causes the rider to lean the "wrong" way.
Because the pegs are too far below the riders center of mass.
Erunanethiel said:
We can apply large enough forces on a day to day basis to move our bodies around.
That's because a rider typically applies forces to the pegs, seat, and handlebars, in addition to exerting torque on the bike.
Likes Erunanethiel
  • #33
I meant that last bit more in terms of walking everyday not moving about on the bike, my bad I wasn't clearSo if we can walk by applying (and getting applied) a force way under our center of gravity, why can't we apply enough force on the pegs?
And I think the rider would end up to the "inside" of the turn if the forces are applied to the pegs and "outside" of the turn, if the forces are applied high up the motorcycle
  • #34
Because a rider is applying a force to a bike that weighs more than the rider.[/quote]
If the forces are applied high up the bike, the forces between tire and pavement may be in the "wrong" direction. Without the self counter-steering related to lean, weight shifting won't work well or at all. I still think the best example of locked steering is a bike on a tight wire, and in that case a balance pole that weighs more than the bike is used, in order to generate enough torque to maintain balance.
Likes Erunanethiel
  • #35
If the forces are applied high up the bike, the forces between tire and pavement may be in the "wrong" direction. Without the self counter-steering related to lean, weight shifting won't work well or at all. I still think the best example of locked steering is a bike on a tight wire, and in that case a balance pole that weighs more than the bike is used, in order to generate enough torque to maintain balance.[/QUOTE]The Earth is much heavier than us too, why doesn't it pose a problem when we push against it when walking but it does when trying to apply a horizontal force on the pegs is what I don't getBy the way I never meant to say locked steering in the first thread or the second one, what I tried to say was "no trail", but I figured it was what I was trying to say after creating the thread and learning what trail is.
  • #36
Erunanethiel said:
The Earth is much heavier than us too, why doesn't it pose a problem when we push against it when walking but it does when trying to apply a horizontal force on the pegs is what I don't get.
When walking, the person is not trying to move the Earth (it only moves a very very tiny amount), but on a bike the person is trying to lean the bike and get the tires to exert a force onto the pavement, which will result in the pavement exerting a force back onto the tires. As previously posted, in some scenarios, the forces between tire and pavement will be in the "wrong" direction, and in other scenarios, even when these forces are in the "right" direction, the rider ends up leaning the wrong way.
The system of bike and rider are a unitrack system, for a coordinated turn, the system first has to be leaned in the desired direction of turn before it actually can be turned in that direction. In some cases, an uncoordinated turn maneuver can be used to avoid potholes: say a bike is headed towards a pothole, and rather than trying to do a normal turn away from the pothole, the rider uses "pro-steer" to steer the tire contact patches around the pothole, and after passing the pothole, steers the other way to return the bike back to vertical. For example, the rider steers right to cause the tires to go around the right side of the pothole, while the bike ends up unbalanced leaning to the left. The rider delays correcting the left lean until after the bike passes the pothole. The advantage of this is that there's no delay waiting for the bike to lean to the right before turning to the right.
Likes Erunanethiel
  • #37
I think we should not try to "move" the bike, but keep it as still as possible, that's why I assumed it's better to apply the forces on the pegs, low down on the bike, so the tires will resist the bikes movement and if the bike doesn't move much to the way the rider pushed it to, the less it cancels the rider's movement and more the combined center of gravity of the system shifts to the side the rider leans in to.
  • #38
Erunanethiel said:
I think we should not try to "move" the bike, but keep it as still as possible ...
Which requires counter-steering if the rider is going to shift weight at the same time. Take a look at this chase video of a motorcycle racer. Note that body movements are done in advance of turning movements, using counter-steering to keep the bike from turning while the rider hangs off to setup for a turn. Also note that lean angle adjustments are made mid-turn without anybody movements. He also transitions from a right to left turn, both shifting from the right side of the bike to the left side of the bike at the same time the bike changes lean angle from right to left, by counter-steering to the right to change the lean of the system of bike and rider.
Maybe you missed this video also from post #5, showing a bike that is particular resistant to "body steering". Skip to 2:15 into the video:
Likes Erunanethiel
  • #39
If the rider doesn't counter steer at the same time he shifts weight, assuming the bike doesn't have any trail, it still would cause the center of gravity of the system to change horizontally, which is what I am trying to say.
  • #40
The point I'm trying to make is both the bike and the rider shift weight, the rider one way, the bike the other way, and which direction the force from the pavement and the center of gravity changes horizontally depends on the scenarios I mentioned in my prior posts.
Likes Erunanethiel
  • #41
The part I don't understand is if we can walk on the earth, shouldn't we be able to use horizontal forces through the pegs? Why the pegs being under our center of gravity would unable us? If we push to the other way first through the pegs, and then we push the way we actually wanted to push, I don't see anything that would make it not possible.
  • #42
My point was that the initial horizontal force applied to the pegs would be relatively small. Why focus on the horizontal forces only and not the vertical forces as well? Once the rider's center of mass is offset from the pegs, the rider can lift off the seat, with the pegs pushing up and gravity pulling down, creating a torque on the rider to cause the rider to lean.
Assuming you're still wondering about a bike with no trail, then that's almost like having the steering locked, and I've already gone through a close analogy of a bike on a tight wire, and what it takes to keep that system balanced (use torque on balance pole to generate a Newton third law pair of forces between wheels and wire).
Likes Erunanethiel
  • #43
Why would the forces applied to the pegs be small? We constantly apply forces to the floor pushing the Earth and it is enough for making us walk or even run. I also don't understand why you say we have to bend at the waist in order to generate a force on the pegs, can't we just use our legs directly to apply the forces?The reason I am focusing on horizontal forces on the pegs rather than vertical forces is because I think making most of the friction between tires and the road in order to lessen the bikes movement to the other way, so it would cancel less of the riders movement, shifting the center of gravity of the system more to the side where the rider leans in to
  • #44
because the forces are being applies so far below the center of mass of the rider.
Other than the initial start (acceleration), the average net horizontal force while walking or running is zero (constant velocity).
If a rider is going to lean and shift to the left to "hang off" to the left on a bike, the rider needs to apply a force to the right at the handlebars, pegs, and possibly the seat.
Likes Erunanethiel
  • #45
As long us we apply a little force to the opposite side to counter the rotation of applying a force (and being applied) below the center of mass of the rider, I don't think it should matter. Like pushing a bit to the right on somewhere on the bike to transfer to weight to the left first. As I think you said in the previous thread
  • #46
Say the rider leans to the left at the waist, exerting a right force onto the seat, and a left force onto the pegs. The opposing forces reduce the net force in either direction, and mostly combine to create a Newton third law pair of torques, where the rider leans left and the bike leans right. There won't be much horizontal force between tires and pavement in this situation.
I'm not sure of the point of this. Weight shifting is just an indirect method of counter-steering that relies on the steering geometry, and on some bikes such as the Keith Code green bike, the bike's setup is such that the net effect of weight shifting is only producing shallow lean angles.Hanging off to the inside in a racing situation can be helpful, as noted in post #4. In a street situation, when not at the limits, it isn't needed. I use counter-steering similar to how ailerons are used on an aircraft, with the main difference being the control input is reversed (right torque on the handlebars results in a left lean and vice versa).
Likes Erunanethiel
  • #47
Do we have to bend at the waist? Can't we just use our legs and push to the other side first as said in my previous post?
There has to be a way to get the center of gravity of the system to change one side or the other without countersteer (direct or indirect) since the system is not a closed one and the tires are touching the ground, so body movements horizontally should cause acceleration to one way.
  • #48
Push with the legs against the seat or with the feet against the pegs?
The issue is that both bike and rider move in response to a Newton third law pair of forces and/or torques applied between bike and rider. The net force has to be applied low enough that the bikes angular momentum about the roll (lean) axis resists the lean reaction to the force, resulting in a force between tires and pavement that accelerates the center of mass of the system into the direction that the rider shifts. The problem is that the rider's center of mass is too high and the rider's relative angular momentum is too low to be able to generate much horizontal force at the pegs.
Again, note that moving the center of mass without countersteer is exactly what happens in the case of a bike on a tight wire, and in that situation, a long balance pole that weighs more than the bike is used to maintain balance, with the rider exerting "counter-torque" on the balance pole to shift the center of mass of the system to keep it centered above the wire.
Likes Erunanethiel
  • #49
I can't quotes separately since I am on mobile so I have to write like this, sorry.
Pushing against the pegs or where the vertical bit where the peg attaches to the bike is what I am saying. After the initial push to the bike, the rider can apply the force necessary to stop him falling can be applied high on the bike, in order to increase the amount that center of gravity of the system can change more. So to start the movement, apply a force as low as possible, and to secure the position, apply a force as high on the bike as possible, to achieve the most change in the horizontal position of the center of gravity of the system.
  • #50
Again the issue is that the initial push at the pegs will be a relatively small force. It's not going to do much to change the center of mass of the system. However, even if the center of mass is only shifted a small amount, then gravity will cause the system to lean in the direction of center of mass offset, which in turn will further move the center of mass of the system, but that this point rider movements could not overcome the effects of gravity and steering would be needed to prevent the system from falling on to its side. Also random disturbances would cause the system to lean, and again rider movements could not overcome gravity without counter-steering.
Likes Erunanethiel
