Move or attract large/heavy materials using polarisation
The discussion explores the theoretical possibility of moving or attracting large, heavy materials using polarization. It references the principle where a charged rod can polarize lighter materials, like paper, allowing them to be lifted. However, the feasibility of this method for larger objects, such as rocks, is questioned due to the immense charge required, which would likely exceed the breakdown voltage of air, causing arcing. The conversation highlights the limitations of polarization in practical applications with substantial materials. Ultimately, while the concept is intriguing, significant challenges exist in applying it to larger objects.
Moustachio
I was just wondering if it was possible theoretically to move or attract large/heavy materials using polarisation.
For example I've heard examples that if you have a charged rod ,and you bring it
close enough to pieces of paper the charge on the rod will polarise the paper and then if that
force between the rod and the polarised paper is large enough you can pick up the piece of paper. So is this possible with basically any material eg. like a rock or something if you have a "big" enough charged rod ?
Science news on Phys.org
I don't think so. The problem with large objects is that they would require so much charge on the rod that it would exceed the breakdown voltage of the air or whatever was holding the rod and it would arc, neutralizing the charge on the rod. I'm not sure if the size of the rod or something else would make a difference or not, so I can't say for sure.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
