Finding Equations of Movement and Acceleration Along a Parabola
  • Thread starter Thread starter CCMarie
    Movement Parabola
The discussion revolves around finding the equations of movement and acceleration for a point moving along the parabola defined by r*cos^2(θ/2) = p/2. The participant initially rewrites the parabola's equation and attempts to derive the movement equation and acceleration, but expresses uncertainty about their approach. Clarifications are provided regarding the definitions of radial and transverse acceleration, with formulas given for their magnitudes. The need to derive differential equations for r(t) and θ(t) is emphasized, as they are interconnected through the parabola's equation. The conversation highlights the importance of understanding the relationship between these variables to solve the problem effectively.
CCMarie
Thread moved from the technical forums, so no Homework Template is shown
I have this problem to solve until tomorrow:
A point moves along the parabola r*cos^2(θ/2) = p/2, p > 0, in the direction that θ increases. At the time t=0, the point is on the verge of the parabola. The velocity is v = k*r, k>0.
What is the equation of movement, the radial acceleration and the transverse acceleration.
I've tried to solve it by rewriting the equation of the parabola r = (-2d)/(1+cosθ), and than I thought about derivation of this equation as both r and theta are functions of t, r(t) and θ(t).
I tried to find the acceleration that is the first derivative of the velocity a = k r'(t). And I wrote the equation of movement as s(t) = 1/2*k*t^2*r'(t).
I don't know if what I did so far is ok. And I am not quite sure how to work with the radial and transverse acceleration.
I would really appreciate some clues. Thank you.
Likes Delta2
I am not sure what you mean by equation of movement (equation of the distance traveled as a function of time t? then your equation for s(t) may not be correct if r'(t) is not constant in time)
However the equation your write for acceleration is the magnitude of transverse acceleration ##a_t(t)=kr'(t)##. The magnitude of radial acceleration is ##a_r(t)=v^2(t)/r(t)=k^2r(t)##.
I believe the assignment asks to write down and maybe solve the differential equations for ##r(t)## and ##\theta(t)##. Have you done any differential equations in your class?
Likes CCMarie
Thank you for your response, [Delta][/2].
By the equation of movement I meant the distance traveled as a function of time. In my case I guess that r(t) shouldn't be constant in time. Am I going to have a partial differential in the expression of s(t)?
I have studied differential equations. But I don't know what are the equations that I have to solve? Where do I obtain the differential equation to be solved from?
Then the equation of movement is ##s(t)=\int v(t)dt+c=\int kr(t)dt+c##
At the moment I am abit sleepy and can't think if we got enough data to find ##r(t)## or ##\theta(t)## as function of time. Of course if we find one of them then we know the other cause they are connected with the equation ##r(t)cos^2(\theta(t)/2)=p/2##.
Likes CCMarie
Thank you very much, Delta^2!
