Moving electron - finding the wavefunction
71GA
On our modern physics class e did a problem:
Write down a wavefunction of an electron which is mooving from left to
right and has an energy ##100eV##.
At first i said: "Oh i know this!" and solved the case like this.
Lorentz invariant: ##E=\sqrt{{E_0}^2 + p^2c^2}##
Schrodinger equation where ##V(x)=0##.
The energy ##100eV## must be the kinetic energy of the electron. So i said ok this kinetic energy is very small compared to the rest energy and i can say that ##pc \ll E_0## which means i have a classical limit where:
\begin{align}
E=\sqrt{{E_0}^2 + p^2c^2}\\
E=\sqrt{{E_0}^2 + 0}\\
\boxed{E=E_0}
\end{align}
So now i can write the general wavefunction for a free right-mooving particle like this:
$$\psi=Ae^{iLx}\quad L=\sqrt{\tfrac{2mE}{\hbar^2}}$$
So if i want to get the speciffic solution i need to calculate the constant ##L## and then normalise the ##\psi##. Because ##E=E_0## i calculated the constant ##L## like this:
$$L=\sqrt{\frac{2mE_0}{\hbar^2}}$$
while my professor states that i should do it like this:
$$L=\sqrt{\frac{2mE_k}{\hbar^2}}$$
where ##E_k## is the kinetic energy of the electron. Who is wrong? I mean whaaaaat? The constant ##L## is afterall defined using the full energy and not kinetic energy...
You're wrong. Both your expression for L and the Schrodinger equation are non-relativistic. It's not appropriate to use the relativistic expression for the energy of the electron here.
Likes 1 person
Thank you.
But can you explain to me why don't we generaly use the rest energy when dealing with a classical approximations. In books everyone explains the rest energy but what it really is? I mean i know how to calculate it and whatsoever but when does it appear and why do we have to take it into the calculation?
I am confused only because of that Lorentz invariance which says that if a particle is mooving slowly most of its energy is the rest energy. On the other hand we just neglect it like it isn't there... It seems to me like a contradiction...
It's just the way you're doing the classical approximation isn't correct. A plane wave is given by $$\psi = e^{i(kx-\omega t)}$$ where ##p= \hbar k## and ##E = \hbar \omega##. For the spatial dependence, you need to find the classical approximation for the momentum p:
\begin{align*}
pc &= \sqrt{E^2 - (mc^2)^2} \\
&= \sqrt{(mc^2+K)^2 - (mc^2)^2} \\
&= \sqrt{2mc^2 K + K^2} \\
&\cong \sqrt{2mc^2 K}
\end{align*} where K is the kinetic energy. The rest energy term cancels out.
The other way to look at it is that ##k = \sqrt{\frac{2mE}{\hbar^2}}## is equivalent to the relationship ##E = \frac{(\hbar k)^2}{2m} = \frac{p^2}{2m}##. This latter expression is clearly the classical quantity for the kinetic energy of a particle of mass m, not the total energy.
Likes 1 person
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
