Particle Decay: Understanding Energies and Four-Momentum | Physics Homework
Gargars
Hello everybody, I'm assigned to do particle physics home, which I don't really understant because I'm a freshman and I have choosen it as a free subject. Obviously, that was a mistake. I have been reading a book, but I'm not sure if I understand everything.
A particle of rest mass M, traveling at speed v in the x-direction, decays into two photons, moving in the positive and negative x-direction relative to the original particle. What are their energies? What are the photon energies and directions if the photons are emitted in the positive and negative y-direction relative to the original particle (i.e., perpendicular to the direction of motion, in the particles rest frame).
I previously solved an equation for particle decay products energies when parent particle is ant rest. These are E1=(M^2+m1^2-m2^2)/2M, and analogicaly for E2, just -m1 squered and +m2 squered.
I'm considering photon which is moving in the positive x-direction to have less energy than the other one. Maybe I should use relatyvistic velocity addition to find these energies?
There is another problem related to the previous one.
If a massive particle decays into photons, explain using 4-momenta why it cannot decay into a single photon, but must decay into two or more. Does your explanation still hold if the particle is moving at high speed when it decays?
The four-momentum:
As far as I understand no particle can decay into another particle without nothing else. But that's not an explanation.
I get it now. Thread closed.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
