Multi-electron eigenfunction problem
  • Thread starter Thread starter RIPCLB
    Eigenfunction
RIPCLB
"Prove that any two different nondegenerate bound eigenfunctions \psij(x) and \psii(x) that are solutions to the time-independent Schroedinger equation for the same potential V(x) obey the orthogonality relation
\int-∞ \psij*\psii(x)dx=0
I believe I have to find equations for which both eigenfunctions are solutions?
I'm lost on how to get the problem started. I cannot think of any eigenfunctions to use. I might be putting more thought to it than I need to though.
Yes, the key is that they are eigenfunctions. But I think you're supposed to prove the orthogonality in the general sense, rather than use specific examples of eigenfunctions.
Suppose that \psi_a(x) and \psi_b(x) are eigenstates of the operator O, with corresponding eigenvalues a and b respectively.
O \psi_a(x) = a \psi_a(x)
O \psi_b(x) = b \psi_b(x)
Now consider each of these cases:
\int_{-\infty}^{\infty} [O \psi_a(x)]^* \psi_b(x)dx = \ \ ?
\int_{-\infty}^{\infty} \psi^*_a(x) [O \psi_b(x)]dx = \ \ ?
I'll let you take it from there. :wink:
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
