Multi-Step linear systems problem - Build ODE, impulse response, systems balance
dankaroll
I messed up on the title of the thread.. I had a few questions but ended up solving them on my own. The only question I have is how to solve this ODE. Thanks.
Solve the ODE
(dx/dt)= f(t) - .1x
Where f(t) = 2+sin(t)2. The attempt at a solution
I faintly remember doing these types of ODE's in diff eq class, but there was always a x/t term so it ended up being a nice equation. Not really sure how to approach one of these though.
I learned this recently in my class. Try moving all the x factors to the left and see if you can do something there.
I think its coming back to me.. I need to find an integrating factor
I found that the integrating factor would be e-.1t
If I multiply both sides by it and integrate I end up with:
e-.1tx = -20e-.1t+int(sin(t)e-.1tdt)
So I end up having the int(sin(t)e-.1tdt)
Which isn't being too cool with letting me solve it.. any suggestions?
You're on the right track.
Remember you have a dx/dt on the left so the equation would be
(dx/dt)+.1x= 2+sin(t)
by turning this into a different notation you get:
x'+.1x=2+sin(t)
So then you can now multiply by the integrating factor and get
e^(.1t)x'+.1e^(.1t)x=2+sin(t)
Does the left side look familiar?
Yes, I think it's coming back to you. I would say the integrating factor is for x'+x/10 is exp(t/10) though. Keep working on it. I think it will come back. To integrate sin(t)*exp(t/10) you integrate by parts. Twice. Is the memory coming back?
As of right now I'm still stumped.. but I did realize I made a mistake with a sign.
After integrating twice I end with:et/10x = 20et/10 + 10et/10sin(t) - 100et/10cos(t) - 100 \intet/10sin(t)dt I think I might see something..
\intet/10sin(t)dt = et/10x-20et/10?Still a noob with the symbols :PThanks for all your help so far!
Try my way...
The left side is just the product rule. So if you do this:
d/dt(e^(.1t)*x)=2+sin(t)
Then you can do a really simple integration. But you could also do it Dick's way.
rey242 said:
Try my way...
I'm all for the easy way (dont shoot me!) but what I don't see in your way is why you only multiplied one side by the integrating factor. Should you multiply the other side as well?
No, what's an x doing in there? You have to integrate exp(t/10)*sin(t)dt by parts using d(-cos(t))=(sin(t))dt. Then you integrate by parts AGAIN and you get the integral of exp(t/10)*sin(t) back again. But with a different sign. Solve for the integral of exp(t/10)*sin(t). I think you've probably seen this before.
Yeah sorry about that, I forgot. :eek:
Multiply both sides by exp(.1t).
The integration is harder now but its still the basic concept.
So I redid my integration and got..
et/10x = 20et/10 - et/10cos(t) - (1/10)et/10sin(t) - (1/100) \intet/10sin(t)dt
cmon brain don't fail me now.. i still don't see it arg
Remember Integration by Parts has "tricks"?
Try setting your equation to
\int exp(t/10)sin(t)dt =20et/10 - et/10cos(t) - (1/10)et/10sin(t) - (1/100)\int et/10sin(t)dt
(I made a mistake with the 1/10 term, should be +)
anywaysOK! I think I figured it out..You can sub the integral parts for a variable.. in this case i'll call it Y
So I solve for Y, plug it back in where the integral was.
for y I ended up with
Y = (100/101)(20et/10 - et/10cos(t) + (1/10)et/10sin(t))
So then u plug it back into where the integral was, exp functions end up canceling out and u get your answer for x
right?
ah, what a complicated answer for such a simple looking problem. math is the master of disguise :)
