geetar_king
- 26
I have a problem that I normally find solutions to via trial and error, and they usually aren't optimized, but was wondering if there is a better way to solve this and optimize.
My application is specific but this is the best way I can describe the problem. Forgive me if it doesn't make sense!
There is a set of 20 balloons laid out in a line. Each balloon initially begins with the same pressure and each has the same volume. All balloons are materially the same.
Now imagine there is a restrictive port connecting Balloon #1 to Balloon #2, Balloon #2 to #3, #3 to #4... ...#18 to #19, and #19 to #20.
This port allows air to pass between the balloons, where the leakage rate from balloon i to j is Lij and is a rate that is a known function of to the pressure differential between balloons.
There is also another port on each balloon, an 'injection port', which connects to the air supply manifold.
Objective/Problem:
Constraints:
Optimization:
So normally I start with a 20 column 2D grid with injection rates in each row at each time for each balloon, and shift rates around and then see what pressure is and try to work with the constraints.
I'm not sure if there is a way to do this mathematically or with matrix operations or something...
Let me know if there are too many unknowns or if something doesn't make sense.
Thanks
Objective/Problem:
The goal is to pressurize all balloons up to Pmax in the quickest amount of time subject to the folllowing constraints.
Constraints:
- The Pressure in balloon #i is a known function of volume in the balloon: Pi = f(Vi)
- Maximum injection rate into any balloon is Pmax.
- Minimum injection rate into any balloon is Pmin, otherwise zero injection rate.
- There is a total air supply capacity, C, so that all injection rate must sum to C (maximize capacity usage)
- A number, N, balloons must be on injection simultaneously at all times in a block formation (ie group of N balloons side by side).
- The maximum pressure differential between any balloons is D.
- Leakage, Lij, as described above is small compared to injection rate. (could consider zero to start with if this complicates things.)
Optimization:
Minimize the amount of 'fillup volume' on each balloon before the balloon reaches Pmax.
Thanks
