Multiplicity of a Einstein Solid, Low Temperature Limit
4 replies · 22K views
TFM
(a)
The formula for the multiplicity of an Einstein solid in the “high-temperature” limit,
q >> N, was derived in one of the lectures. Use the same methods to show that the multiplicity of an Einstein solid in the “low-temperature” limit, q << N, is
Ω(N,q)=(eN/q)^q (When q≪N)
(b)
Find a formula for the temperature of an Einstein solid in the limit q << N. Solve for the energy as a function of temperature to obtain U=Nϵe^(-ϵ/(k_B T)), where ε is the size of an energy unit.
N/A
Okay, I have started (a):
[tex]\Omega (N,q) = (\frac{(N - 1 + q)!}{(n - 1)!q!})[/tex]
N large:
(N - 1)! approx = N!
[tex]\Omega (N,q) = (\frac{(N + q)!}{N! q!})[/tex]
Take logs
[tex]ln(\Omega (N,q)) = ln(N + q)! - ln(N!) - ln(q!)[/tex]
Use Stirling aprrox:
[tex]ln N! \approx N ln(N) - N[/tex]
[tex]ln(\Omega (N,q)) = (N + q)ln(N + q) - (N + q) - (Nln(N) - N) - (qln(q) - q)[/tex]
Cancels down to:
[tex]ln(\Omega (N,q)) = (N + q)ln(N + q) - Nln(N) - qln(q)[/tex]
Now I have to use the Taylor Expnasion for q << N, but I got slightly confused here.
Could anyone please offer some assistane what I need to do from here?
Many thanks in advance,
TFM
TFM said:
Cancels down to:
TFM
You need to write the (N+q) log like this (below) and then just copy the lecture derivation, I think. You can show how you use the taylor expansion, but I would have said it's not necessary
[tex]ln(N+q)=ln(N(1+q/N))[/tex]
Okay, so now:
Use Taylor Expansion:
[tex]ln(N+q)=ln(N) + ln(1+q/N))[/tex]
now the notes say:
[tex]ln(N+q) = ln(N) + q/N[/tex]
Althought I am not sure why the last ln has dissapeared?
Now plug into omega to give:
[tex]ln(\Omega (N,q)) = (N + q)(ln(N) + q/N)- Nln(N) - qln(q)[/tex]
Multiply out:
[tex]ln(\Omega (N,q)) = NlnN + q + q^2/N + qlnN - Nln(N) - qln(q)[/tex]
Cancel down:
[tex]ln(\Omega (N,q)) = q + q^2/N + qlnN - qln(q)[/tex]
Now the notes have that:
because q >>N,
N^2/q approx 0
So for
because q <<N,
This should still be
q^2/N approx 0
thus:
[tex]ln(\Omega (N,q)) = q + qlnN - qln(q)[/tex]
take exponentials
[tex]\Omega (N,q) = e^q + (N/q)^q[/tex]
Thus
[tex]\Omega (N,q) = (eN/q)^q[/tex]
Does this look okay?
TFM said:
Okay, so now:
This is just rearranging (not using a Taylor series)
TFM said:
now the notes say:
You should say, [tex]ln(N+q)=ln(N(1+q/N))=ln(N) + ln(1+q/N)[/tex]
You can then take the Taylor expansion of the last term in the above, namely
[tex]ln(1+q/N)[/tex], provided you assume q<<N so that q/N<<1. If you look up the Taylor expansion for ln(1+x) you will find that it says this is approximately equal to x in the limit x<<1.
take exponentials
Here there is an error. When you exponentiate an equation the entire right side is raised to the same exponential. Also [tex]e^x+e^y \neq e^{x+y}[/tex]
Okay so:
so I have to take exponentials,
[tex]\Omega (N,q) = e^q + e^qlnN - e^qln(q)[/tex]
[tex]\Omega (N,q) = e^q + Ne^q - qe^q[/tex]
So now do we use the log/exponential rules to give?
Also,
Where woul be aq good place to start for here?
