How Many Laps Will a Muon Complete Before Decaying?
The discussion revolves around calculating the number of laps a muon completes in a circular orbit before decaying, based on its speed and relativistic effects. Participants clarify that assuming the muon travels at the speed of light is misleading since it has mass and cannot reach that speed. The correct approach involves using the muon's relativistic energy and rest mass to determine the gamma factor, which is then used to calculate the muon's lifetime in the lab frame. The mean lifetime of the muon is identified as 2.2 microseconds, leading to a final calculation of approximately 440 laps around the 14 m diameter ring. The conversation emphasizes the importance of correct unit conversions and understanding relativistic principles in solving the problem.
genloz
The most precise measurement of the anomalous magnetic moment of the muon (g-2) is performed at Brookhaven (USA). In this experiment muons are held in a circular orbit in a 14 m diameter ring, with momentum 3.098 GeV. On average how many laps of the ring the muon will do before decaying? (hint: assume the the muons goes at the speed of light).
None given
I figure this is related to reltivity, so the muon's clock is running slow...
T=\gamma T_{0}
(T=gamma T0)
but if v is assumed to be c, the gamma factor is infinity?
But I'm confused about how to work out a decay from energy when no decay time is given?
Is there a list of formulas anywhere that would apply to this situation?
Thanks!
That question is rather silly, since it says that you must assume it goes at the speed of light, but if that was the case, then it would have to be massless, and since it wouldn't experience time, it would never decay. It may be a trick question, but as it stands, the answer would be an infinite number, since it doesn't experience time, that said, it couldn't go at c, since it has mass, but then if it was massless, it wouldn't be confined using traditional methods - you would need a gravitational field.
The question isn't so much silly, as badly phrased. Get the gamma by comparing muon energy to rest mass. Use the gamma to get lifetime in the lab frame. Now use the hint. You don't have to use gamma to compute v because you know it's REALLY close to c. Just use v=c to find how many laps.
So:
muon energy = 3.098 c GeV
speed of light in GeV = ??
muon rest mass = 0.1066 GeV
Gamma = (3.098c - 0.1066)/(0.1066*c^2) = ??
T = gamma T0
c/T = distance
distance / 2*pi*7
= number of laps
is that correct? and how do I fill in the blanks?
Thanks!
Are you making these formulas up? Your units are all wrong. Relativistic energy is gamma*(rest mass)*c^2. Did you look up T0? What's the lifetime of the muon in the rest frame? Energy is measured in GeV. Mass is measured in GeV/c^2. Or energy is measured in joules and mass in kg. You might wish to convert to the usual units. But how can you say distance=c/T? c is in m/sec and T is in sec. If you go back and put correct units on everything I think it will help you a lot.
Ok, thanks...
so gamma = relativistic energy/(restmass*c^2)
muon rest mass = 105.6 MeV/c2 = 0.1056 GeV/c2
gamma = 3.098GeV/(0.1056 GeV) = 29.337
t(rest) = gamma*t(muon)
but i don't know the lifetime of the muon in the rest frame as I wasn't given a decay rate or lifetime or anything... so how can this question be completed?
Thanks for all your help!
Much better. For the muon lifetime you just have to look it up. There is no formula.
Ok, so I think I have it now... Thanks again for all your help!
mean muon lifetime = 2.2ms
t = 0.0022s*29.337 = 0.0645414s
d=s*t
d=3*10^8m/s * 0.0645414 = 19 362 420m
number of laps = 19 362 420/(pi*7*2)
so 440 232 laps?
seems like a very large number...
Well, it's not as big as you think. Because for the muon lifetime the 2.2 is in microseconds, not milliseconds. But other than that you've made a great improvement!
thankyou :-)
so more like 440 laps then? I guess that's more believable...
I'll buy that. High energy muons can penetrate thousands of meters into the ground. Not millions.
