My Fault Experiment: Hot Water & Earth's Crust
  • Thread starter Thread starter Mkbul
    Experiment Fault
A new model simulating Earth's crust was created using two broken bricks in a confined area, with hot water representing magma. The experiment observed that the hot water filled a fault between the bricks, causing them to slightly separate due to the pressure from the heat. The experimenter expressed uncertainty about the validity of their findings and welcomed suggestions for improvement. They also inquired about conducting the same experiment with cold water, noting that while the fault became wet, the bricks did not move apart as observed with hot water.
Mkbul
Ok, so today i made a new very simple model and i'd like just to discuss it with you all.
Ive put a broken brick (x, y, z: 10, 2.5, 4 Splited up to 5, 2.5 and 5 (cm)) together in a marked with walls (20cm x 20cm x 5cm) area. The bricks were representing the Earth's crust. I've then brought a small can with Very hot water painted in red to represent the magma. I've then splited it inside the area. The sample of hot water (magma) was a pretty big amount to fill up the whole area. As i was watching the progress of it I've noticed that the fault inside the 2 bricks was slightly filling up the water and the water splited apart the 2 bricks at a very small distance.
What i believe is that the heat of the water forced the 2 bricks apart because of the pressure the hot water had.
Sorry if this was a bad experiment but I'm not that old to know all this stuff! Also I am sorry if my english are not readable, I'm Greek!
I accept suggestions to make again the experiment better!
Have you tried doing the same experiment but with cold water? Do the blocks still move as you previously observed?
Well yeah, once again the fault becomes wet, but the bricks are not forced away
Thread 'The Secrets of Prof. Verschure's Rosetta Stones'
(Edit: since the thread title was changed, this first sentence is too cryptic: the original title referred to a Tool song....) Besides being a favorite song by a favorite band, the thread title is a straightforward play on words. This summer, as a present to myself for being promoted, I purchased a collection of thin sections that I believe comprise the research materials of Prof. Rob Verschure, who at the time was faculty in the Geological Institute in Amsterdam. What changed this...
