Understanding N-point Correlation Functions in Particle Scattering Processes
In summary, correlation functions can be used to interpret the amplitude for a particle to propagate from one point to another. For 3-point or higher correlation functions, they are used when calculating scattering cross sections. These functions can also be used to create diagrams, known as Feynman diagrams, where the number of particles corresponds to the number of external points. While odd numbered correlation functions may exist, they do not contribute to the overall calculation.
copernicus1
99
For a two-point correlation function, it's my understanding we can interpret this as the amplitude for a particle to propagate from one point to another. Is there a similar interpretation for 3- or higher-point correlation functions? When are these used?
Thanks!
They are used when calculating the scattering cross sections.
you can always contract one field to another one, not in adjacent to the first one and you still have a green function.You can contract any two and the result for contracting is the green function multiplied by other operator that remained.For example if you have
<0|T{ψ1ψ2ψ3ψ4)|0> then you will have GF(1-2)GF(3-4)+...,where ... is for other two choices.Those operator which are not contracted gives zero.You will not have an odd term like 3 point because that will give zero(contract with who).So you can still apply the interpreatation you want,for particle being created at 1, destroyed at 2 and particle created at 3 ,destroyed at 4.You can create diagrams using these,called feynman diagrams.Some of these diagrams will be disconnected ,you just leave them.you can use these diagram to calculate amplitude.
As I understand it the name 2,3,4... correlation function is coming from how many particles you have (or they call them external point in the Feynman diagrams). In the 2-point function you have 2 external fields at let's say space points x1 and x2. You can connect them by a line and that is it - the propagator. With 4-point function you have 4 points, You are connecting them 2 by 2 (this is the Wick contraction) in many ways now. For example you can have two electrons entering, two going out, no interaction (the lines do not cross) and the probability for this process is in the 4-point function. But you can have them interacting with each other (the lines now cross) and this is also contributing to the 4-point function. So in other words if you want to calculate scattering of 2 particles this is a 4-point function. As I imagine it n-point will be n particles scattering. I cannot imagine 3-point function that is not a fully disconnected one (when you connect each point to the other two, kind of a triangle shape) but those are part of the energy expectation of the vacuum and are zero at the end. So it is for all odd numbered correlation functions.
1. What are N-point correlation functions?
N-point correlation functions are statistical tools used in physics and other scientific fields to study the relationship between multiple variables. They measure the degree of correlation between N different quantities, providing information about the spatial distribution and clustering of those variables.
2. How are N-point correlation functions calculated?
N-point correlation functions are typically calculated by measuring the joint probability distribution of the N variables in question. This involves collecting data and analyzing it using statistical methods such as Fourier transforms or Monte Carlo simulations.
3. What is the physical significance of N-point correlation functions?
N-point correlation functions have several physical interpretations, depending on the field of study. In cosmology, they are used to understand the large-scale structure of the universe and the distribution of galaxies. In materials science, they can provide information about the arrangement of atoms and molecules in a substance.
4. What is the difference between 2-point and higher N-point correlation functions?
The difference lies in the number of variables being studied. 2-point correlation functions measure the correlation between two variables, while higher N-point correlation functions measure the correlation between more than two variables. Higher N-point correlation functions provide more detailed information about the relationships between multiple variables.
5. What are some applications of N-point correlation functions?
N-point correlation functions have a wide range of applications in different scientific fields. In addition to cosmology and materials science, they are also used in fields such as astrophysics, ecology, and economics. They can help understand the behavior of complex systems and provide insights into the underlying mechanisms at work.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
