What is the Name and Construction Process for Interlocking Gear Mechanisms?
  • Thread starter Thread starter NextDaVinci
The discussion centers on identifying interlocking gear mechanisms, specifically referred to as Hirth Joints, which feature circular faces that interlock to allow rotation when unlocked. Participants suggest consulting the manufacturer's manual for specific terminology and mention alternatives like locking screws or pins. Basic construction advice includes using a bolt to create a stiffer joint, with options for more complex designs involving toothed wheels and pins for angular locking. The conversation emphasizes the importance of understanding the mechanism's operation for effective design. Overall, the thread provides insights into both naming and constructing these mechanisms in a machine shop setting.
NextDaVinci
I am referring to the gear-like circular faces that interlock when forced together and allow rotation when unlocked on these arms. I want to design one, but I can't seem to find out what its called.
Any advice as to how to make these out of metal in a basic machine shop is also welcome.
Thanks!
Welcome to PF;
Have a look in the manual that comes with it to find out what the manufacturer calls them.
I know them as "locking screws" or "locking pins" depending on their operation.
The simplest operation is just to have a bolt through the joint - tightening the bolt makes the joint stiffer.
After that you can have all the fun you like with toothed wheels and pins - which will only lock the joint at particular angles.
Well done.:)
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
16K
