How Does a Charge Distribution with Zero Total Charge Exist?
  • Thread starter Thread starter humo90
    Physical Picture
humo90
Need a physical picture!
The electric potential of some charge configuration is given by V(r) = A*e^(-λr) / r
Its Electric field is E = A*[(λr+1)/(r^2)]*e^(-λr) \hat{r}
And its charge density is ρ = 4*pi*A*ε0*δ(r) - [(ε0*(λ^2)*A*e^-λr) / r] , where δ(r) is delta function.
The thing that surprised me is the total charge is zero (Q = 0), how could this happened since I have a charge density? and can someone help me answering the following two questions.
1. What is the physical picture of the charge density (=how does the charge density look
like)?
2. Where could a charge density of this form appear in nature?
Its Electric field is E = A*[(λr+1)/(r^2)]*e^(-λr) rˆ
like)?
Hi, How have you figured out that the total charge is zero exactly?
For a picture of the charge density its worth simplifying the statement of charge density by putting all the constants together, unless I have made a mistake does this make sense?
ρ(r)=B*δ(r)-C\frac{e^{-Dr}}{r}
It is then a case of taking several significant values of radial points (it should already be clear it is spherically symmetric) and considering the value of the charge density given that B and C are positive. Does this help?
Once you have the shape and given the spherical nature the second question should make more sense.
A charge distribution of this nature appears when you place a point charge in a plasma. The point charge is screened by the ions/electrons of the plasma.
To get the total charge, I took the volume integral of the charge density, that is
Q = ∫ρ dv = ∫(4*pi*A*ε0*δ(r) - [(ε0*(λ^2)*A*e^-λr) / r]) dv
= (4*pi*A*ε0) ∫δ(r) dv - (ε0*(λ^2)*A) ∫((e^-λr) / r) dv
= (4*pi*A*ε0) - (ε0*(λ^2)*A) ∫∫∫((e^-λr) / r) (r^2)*sin(∅)*dr*d∅*dθ,
since ∫δ(r) dv = 1
and dv = (r^2)*sin(∅)*dr*d∅*dθ in spherical coordinates.
Also, ∫∫∫((e^-λr) / r) (r^2)*sin(∅)*dr*d∅*dθ = (4*pi*ε0*(λ^2)*A)((1/λ^2)-((r*e^-λr)/λ)-((e^-λr)/(λ^2)),
and for entire space: r goes to ∞, we get ∫∫∫((e^-λr) / r) (r^2)*sin(∅)*dr*d∅*dθ = (4*pi*ε0*A).
Hence, Q = (4*pi*A*ε0) - (4*pi*ε0*A) = 0
I am really still confusing about understanding this problem.
Hi, your working appears correct. I am not 100% but taking Dickfore answer this solution would make sense. The total enclosed charge is zero due to screening by the plasma. Sorry I can't be of any help
There is a positive point charge in the middle and negative charge distribution around. It is somewhat similar to a spherical capacitor with a very small inner sphere, with positive charge, and a grounded outer sphere where negative charges accumulate. There is an electric field between the spheres, there is a charge distribution, and the total charge of the capacitor is zero.
ehild
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
