Conversion Help: Ounces to mL for .45L Tank
  • Thread starter Thread starter Sufa
To treat a 0.45-liter tank with fuel stabilizer, approximately 0.04 fluid ounces is needed, which is slightly more than one milliliter. This calculation is based on the treatment ratio of one fluid ounce for every 2.5 gallons. The discussion highlights the distinction between mass and volume units, noting that ounces measure mass while gallons measure volume. The conversion from liters to gallons is also clarified, with 0.45 liters equating to about 0.1 gallons. Overall, the thread emphasizes the importance of accurate measurements for effective treatment.
Sufa
Hi newguy here :blushing:
Heres the problem:
If one fluid ounce treats 2-1/2 gallons, how many ounces (or mililiters) are to be added to a .45 liter tank?
I want to add fuel stabilizer to my weed eater gas tank.
Mathematics news on Phys.org
IIRC,"ounce" (avoirdupoids) is a unit for MASS,while "gallon" is for VOLUME/CAPACITY...So u need the density...
So it's not "OUNCES (or MILLILITERS)",but OUNCES...
Daniel.
P.S.Roughly 1 gallon=~4.54l...In the UK,or 1 gallon=~3.78l in the US.
I'll take mililiters also. Density? Don't know that. The bottle simply says 1 ounce treats 2-1/2 gallons (U.S.) The tank is .45 liters. Just assume the tank is full of gas. Maybe that's the density.
0.45 litres is roughly 0.1 gallons (actually 0.099 british gallons or 0.119 US gallons - found this here, not sure which you're using). So if one fluid ounce treats 2.5 gallons and you want to treat 0.1 gallons you'll need 0.1/2.5 = 0.04 fluid ounces, which is little more than one millilitre:
\frac{1\mbox{ fl-oz}}{2.5 \mbox{ gal}} = \frac{x \mbox{ fl-oz}}{0.1\mbox{ gal}} \implies x = \frac{1\mbox{ fl-oz}}{2.5 \mbox{ gal}}\times 0.1\mbox{ gal} = 0.04\mbox{ fl-oz}
Hope that helps.
Thank you!
Google is really very useful for these things. For example, you could type speed of light in furlongs per fortnight, and it will convert it for you.
Just a tip :wink:
Just a tip :wink:
How about feet per eternity...?? :confused: Can they do that? :bugeye:
Daniel.
