Need help badly, calculating the rate of falling objects
  • Thread starter Thread starter stumphead101
    Falling Rate
To determine the speed of the mailbag after 4 seconds, it is assumed that it has the same initial velocity as the helicopter, which is 2.68 m/s downward. After release, the mailbag accelerates towards the Earth at 9.81 m/s² due to gravity. The final speed can be calculated using the equation v = initial velocity + (acceleration × time). Thus, after 4 seconds, the speed of the mailbag will be 2.68 m/s + (9.81 m/s² × 4 s). The resulting speed is straightforward to compute.
stumphead101
A small mailbag is released from a helicopter that is descending steadily at 2.68 m/s.
(a) After 4.00 s, what is the speed of the mailbag?
v = ?
i think you can assume that the mail bag has an initial velocity identical to that of the helicopter.
Once it has been released in midair, it will start accelerating at 9.81 m/s^2 to earth, the calculation becomes trivial
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
