Need help finding contour for this integral
  • Thread starter Thread starter quasar_4
    Integral
quasar_4
Hi everyone. I'm trying to integrate the function
\int_0^{\pi} \frac{1}{(1+\cos{\theta}) \sqrt{1+q^2 \cos^2{\theta}+2q\cos{\theta}-p^2 \sin^2{\theta}}} d\theta
analytically, where p and q are constants satisfying p^2 + q^2 =1.
p^2 + q^2 =1
\cos{\theta} = \frac{1}{2}(e^{i\theta}+e^{-i\theta}), \sin{\theta} = \frac{1}{2i}(e^{i\theta}-e^{-i\theta})
Residue theorem, Cauchy's theorem, etc
It seemed to me that the only way to do this was as a contour integral, so I made the substitution
z = e^{i\theta} \rightarrow dz = iz d\theta \rightarrow d\theta = -i/z dz.
Using the above trig substitutions, I simplified and got the integral
\int \frac{1}{(1+z)^2 \sqrt{4+2(q^2-p^2)+\frac{1}{z^2}+z^2+\frac{4q}{z}+4qz} }dz.
It's still rather ugly, but I can see that there is a pole of order 2 at z=-1. I think I can neglect the roots of the stuff in the square root because each root has a factor of (-1+p^2+q^2) = 0 in the denominator, making all roots infinite. The issue now (assuming my pole analysis is ok) is to choose a contour, but because the sqrt in the denominator is not single valued I need to make a branch cut. Also, I'm integrating from 0 to pi, so that's a half circle in the complex plane. I can't see how to make a contour that includes both the branch cut and goes around the pole at z=-1. Can anyone help, or at least tell me if what I've done so far is valid? :)
A little simplification of the radicand could make things much nicer for you:
\begin{aligned}1+q^2 \cos^2{\theta}+2q\cos{\theta}-p^2 \sin^2{\theta} & = 1+(1-p^2) \cos^2{\theta}+2q\cos{\theta}-p^2 \sin^2{\theta} \\ & = 1+\cos^2{\theta}+2q\cos{\theta}-p^2 (\sin^2\theta+\cos^2\theta) \\ & = 1+ \cos^2{\theta}+2q\cos{\theta}-p^2 \\ & = q^2 +\cos^2{\theta}+2q\cos{\theta}\end{aligned}
...and that looks a lot like a perfect square to me :wink:
ooo, that makes me VERY happy! :-) :smile:
Now it's cute and simple and just has a pole of order 4 at z=-1. No icky branch cuts! Yay!
THANK YOU!
THANK YOU!
You might still need to be a little careful since
\sqrt{a^2}=|a|=\left\{\begin{array}{lr}a, & a \geq 0 \\ -a, & a<0\end{array}\right.
Unless you know for certain that q\geq 1, your radicand will have two different branches.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
