Need help on another electromagnetic problem
  • Thread starter Thread starter andrew410
    Electromagnetic
A uniform circular disk with a mass of 27.0 g and a radius of 37.0 cm is subjected to electromagnetic radiation, causing it to rotate. The radiation pressure can be calculated using the formula F = P/A, where P equals the intensity of the radiation. The area of the disk is determined as A = πr^2, leading to the force exerted by the radiation. Torque is calculated using τ = Fd, where d is the distance from the hinge, and the moment of inertia is found using I = (1/2)mr^2. The angle of rotation is derived from the relationship between torque and moment of inertia, ultimately leading to the calculation of angular acceleration.
andrew410
A uniform circular disk of mass 27.0 g and radius 37.0 cm hangs vertically from a fixed, frictionless, horizontal hinge at a point on its circumference. A horizontal beam of electromagnetic radiation with intensity is incident on the disk in a direction perpendicular to its surface. The disk is perfectly absorbing, and the resulting radiation pressure makes the disk rotate. Find the angle through which the disk rotates as it reaches its new equilibrium position. (Assume that the radiation is always perpendicular to the surface of the disk.)
I used the formula P = S/c, where P is the pressure and S is the Poynting vector and c is the speed of light. I made P = (2*S*cos(theta)^2)/c and solved for theta, but the answer was incorrect. I kind of felt this wasn't the right way of doing it because I didn't use the mass or radius in the problem. I need some help...any help would be greatly appreciated. Thanks! :)
One needs to determine the net force of the light. Apply the force at the center of mass.
The center of mass rotates upward to a new elevation and the mg[/itex]\Delta h[/itex], The light pressure (force) balances the lateral (horizontal) component of the gravity force. Assume small angle.
Hi there! It's great that you're trying to solve this electromagnetic problem. Let's break it down step by step.
First, we need to find the force exerted by the radiation pressure on the disk. This can be done by using the formula F = P/A, where F is the force, P is the pressure, and A is the area of the disk. Since the disk is perfectly absorbing, we can assume that all of the radiation is absorbed and the pressure is equal to the intensity. Therefore, P = I.
Next, we need to find the area of the disk. Since the disk is circular, its area can be calculated using the formula A = πr^2, where r is the radius of the disk. Plugging in the given values, we get A = π(0.37m)^2 = 0.1369 m^2.
Now, we can plug in the values for force and area into the formula F = P/A to get F = I/0.1369 m^2.
Since the force is acting on the disk at a distance of 0.37m from the hinge, we can use the formula τ = Fd to find the torque exerted on the disk. Plugging in the values, we get τ = (I/0.1369 m^2)(0.37m) = 0.37I Nm.
Finally, we can use the formula τ = Iα, where τ is the torque, I is the moment of inertia, and α is the angular acceleration, to find the angle of rotation. Since the disk is rotating at a constant speed, we can assume that it has reached its equilibrium position and α = 0. Therefore, we can rearrange the formula to get α = τ/I.
The moment of inertia of a disk can be calculated using the formula I = (1/2)mr^2, where m is the mass of the disk and r is the radius. Plugging in the given values, we get I = (1/2)(0.027 kg)(0.37m)^2 = 0.000749 kgm^2.
Now, we can plug in the values for torque and moment of inertia into the formula α = τ/I to get α = (0.37I Nm)/(0.000749 kgm^2) = 493.99 rad/s^2.
Since the disk starts
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
