Need help on torques / magnetic fields
The discussion focuses on calculating the ratio of maximum torques experienced by a square coil and a rectangular coil made from the same length of wire and carrying the same current in a magnetic field. The key formula for torque, t = NIABsin(θ), is referenced, where the magnetic dipole moment is crucial. Participants clarify that the rectangle's dimensions must be correctly defined, noting that its long sides are twice the length of its short sides. The correct approach involves using the perimeter equality to express the rectangle's dimensions in terms of the square's side length. Ultimately, the ratio of the areas leads to the conclusion that the ratio of maximum torques is 1/2.
vaxopy
A square coil and a rectangular coil are each made from the same length of wire. Each contains a single turn. The long sides of the rectangle are twice as long as the short sides. Find the ratio tsquare/trectangle of the maximum torques that these coils experience in the same magnetic field when they contain the same current.
Im very confused how to do this :/
Let L be length of the squares sides. Using the fact that the perimeter's are equal you can write the length and width of the rectangle in terms of L.
Remember that torque = u X B where u is the magnetic dipole moment of the loop. Since there is no requirement for the magnitude or direction of B, you can just let B=1 and be perpendicular to u so that u X B = u.
i don't know if i did this right
it seems too easy..
t = torque, s=square, r=rectangle
t = NIABsino (o = theta)
ts/tr = NIAsB/NIArB = As/Ar = L^2/2L^2 = 1/2
is this right?
Your right in that it's just the ratio of the areas, but you don't have the correct area for the rectangle. You know that 2 sides of the rectangle are twice as long as the other sides.
Use a different variable to define the sides of the rectangle then use the fact that the perimeters are the same to find the sides of the reactangle in terms of L.
