swooshfactory
- 61
A tank contains 3200 L of pure water. A solution that contains 0.11 kg of contaminent per liter enters the tank at the rate 8 L/min. The solution is mixed and drains from the tank at the same rate.
with C representing the amount of contaminent in kg at time t (in minutes), write a differential equation that models this situation.
possibly int(udv) = uv - int (vdu) (integration by parts)
rate in: 8 L /min * .11kg/ L = .88 kg/min I am confused about where to put the variable t here. From my solution, it would appear that .88/t would be right, but then the rate in would decrease over time. This doesn't seem right. Would it be .88t or .88/t or just .88?
rate out: 8 L/min * C(t)/3200L = C(t)/400 kg/min.
DC/dt= rate in - rate out
DC/dt= .88t - C(t)/400
Is this correct? Should I have added the "t" when it is kg/min?
***In my most recent attempt at this problem, I have come up with:
dC/dT = .88 - C(t)/400
