Need help solving equations in mechanics class?
  • Thread starter Thread starter chubsmalone
    Unknowns
In a mechanics class, a student is struggling to solve an equation involving trigonometric functions: -180 = 217.5*cos(theta) + 101.9*sin(theta). The discussion highlights the need to apply trigonometric identities to rewrite the equation in a solvable form. Key insights include using the relationship A*cos(theta) + B*sin(theta) = √(A² + B²)sin(θ + δ) and understanding the conditions for a solution based on the range of sine and cosine functions. The conversation emphasizes the importance of mastering these equations for future applications in physics and engineering. Overall, the student is encouraged to practice these concepts to gain confidence in solving similar problems.
chubsmalone
I'm in a mechanics\statics class and have run across a couple of problems that I cannot, for the life of me, remember how to solve. The problems end up solving for two unknowns with two equations and one of the equations has
Constant = Constant Sin(theta) + another constant Cos(theta)
and the other equation has sin(theta) and some other unknown.
My statics teacher will help me set up the engineering parts of the problem, but refuses to help me with the math. I should know how to do this, but I can't find it in any of my notes. I appreciate any help anyone can provide for this.
Thanks,
Josh
Mathematics news on Phys.org
Don't both equations have to have both unknowns in them to solve them using a realation?
Could you write out the actual 2 equations u have and the 2 unknowns?
A = B * sin(theta) + C * cos(theta)
you can find the value of `theta' from this equation. the idea is to represent the right-hand side as sin(theta + alpha), where alpha depends on B and C.
-- Adil
Allright,
I was mixed up here when I asked for help. I only have 1 equation, but I still can't solve it. The Eq is -180 = 217.5*cos(theta) + 101.9*sin(theta). I don't know how to solve for theta in this type of equation. I see sadrul's post below, but I'm not sure how to apply it. Thanks again for the help.
--Josh
To know how to solve an equation of the form
A\cos\theta + B\sin\theta = C
you must know two identities in trigonometry, namely
\sin(A+B) = \sin A\cos B + \cos A\sin B
\cos(A+B) = \cos A\cos B - \sin A\sin B
Additionally, you should know that both sine and cosine functions oscillate between -1 and +1. They can of course, assume the values -1 and +1. With a bit of work, you can show that
A\cos\theta + B\sin\theta = \sqrt{A^2 + B^2}\sin\((\theta + \delta)
where \delta = \sin^{-1}\frac{A}{\sqrt{A^2 + B^2}}
Let's leave this an exercise for you so that you are at home with these equations (which will frequently arise in physics, engineering and trigonometry).
From the above description, it should be clear that the equation will have a solution if and only if
-\sqrt{A^2 + B^2} \leq C \leq +\sqrt{A^2 + B^2}
When you rearrange the final equation to solve for theta, you will most likely (except in mathematics where a general solution is required normally) attempt to find the principal value of the argument. That will be easy as you can simply find the inverse function using either a calculator or tables.
Hope that helps...
Cheers
Vivek
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
