Why Does Raising Both Sides of a Logarithmic Equation Yield a Different Result?
  • Thread starter Thread starter christian0710
Raising both sides of a logarithmic equation involves applying the properties of exponents correctly. The equation logS = a - 0.0018t transforms to S = 10^(a - 0.0018t) when both sides are raised to the power of 10. This is because the rule states that 10^(a - b) equals 10^a divided by 10^b, not the sum of the individual exponentials. Misunderstanding this can lead to incorrect conclusions, such as assuming 10^(a - b) equals 10^a - 10^b. Understanding these exponent rules is crucial for correctly manipulating logarithmic equations.
christian0710
Hi I don't understand why this is true:
If you have the function logS = a -0,0018t
and you raise both sides of the equation in 10 you should get
S = 10^(a) - 10^(-0,0018t)
but in my book they get
S= 10^(a - 0,0018t)
When you raise both sides of the equation in 10, should you not raise the individual terms on each side and NOT the whole side?
No, you shouldn't! 10^(a+ b)= (10^a)(10^b) NOT "10^a+ 10^b".
S= 10^(a - 0,0018t)
You "should" learn the rules of of exponents:
x^(a+ b)= (x^a)(x^b)
and
(x^a)^b= x^(ab)
S= 10^(a - 0,0018t)
You seem to think that 10^(a-b) = 10^a - 10^b. Why don't you check this out for yourself? If a = 2 and b = 1, we have c = a-b = 2-1 = 1, so 10^c = 10^1 = 10. Do you agree so far? Now 10^a - 10^b = 10^2 - 10^1 = 100 - 10 = 90. OK still? So, now: do you really think that 10 = 90?
In general, what is true is that ##10^{a+b} = 10^a \times 10^b## and ##10^{a-b} = 10^a \div 10^b##. In fact, that is the whole point of logarithms: you can do multiplication or division by addion or subtraction of logarithms.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
