How Do You Calculate IV Drip Rates for Medications?
To calculate the IV drip rate for a patient weighing 70 kg with a prescription of 0.5 mg/kg/hr, the required dosage is determined to be 35 mg/hr. Given a bag containing 250 mg in 50 mL, the calculation shows that the infusion rate should be set at 7 mL/hr. The conversion process involves canceling units appropriately to ensure accuracy. The calculations confirm that 35 mg/hr is the correct dosage needed for the patient. Overall, the method used for determining the drip rate is validated as correct.
acehansen
Your patient weighs 70 kg the prescription states 0.5 mg/kg/hr. You have a bag of 250 mg in 50 mL. At what rate (mL/hr) will you set the pump?
I don't think I have to convert the units of this equation, just cancel them out... but I'm not entirely sure.
I tested it out, this is how i answered it
0.5/mg/kg/hr X 70kg = 35mg/hr
35 mg/hr X 50ml/250mg (I cancel out mg)
= 7ml/hr
I am not sure if I did this correctly.
How many milligrams per hour does the whole of the patient need ?
35 mg/hr is fine.
you know 250 mg is 50 ml, so 35 mg /hr is 35/250 * 50 mg/hr * ml/mg
You and patient can rest assured that this is correct.
Welcome to PF :) (though this is more like artihmetic, isn't it ?)
35 mg/hr is fine.
Thank You BvU. :)
