How Do You Solve Complex Kirchhoff's Law Problems?
The discussion revolves around solving complex Kirchhoff's Law problems, with a focus on finding the current through each resistor using provided equations. The user expresses difficulty in understanding how to mathematically derive the currents, despite having correct equations. Participants emphasize the importance of clearly presenting attempts and details for effective assistance, suggesting the use of LaTeX for clarity. An error in the user's equations is identified, highlighting the need for careful verification of calculations. Overall, the thread underscores the necessity of clear communication and detailed problem-solving steps in physics discussions.
BirdK
http://file:///Users/jarrettwingfield1/Desktop/Screen%20Shot%202016-09-29%20at%205.29.21%20PM.png My professor told me my equations were correct, but I do not know how to find the current through each resistor mathematically, and every example I find online is too simple so it doesn't help me.
My equations are: i1=i2+i3; -2i2 - 6i1 = -8 ; 2i2- 4i3 = -12
An online calculator says i1=0.857 i2=-1.429 and i3= 2.286
I
[/B]
Hi BirdK, Welcome to Physics Forums.
Your image is not visible, likely because it's hosted on your machine. Can you upload it? (Use the UPLOAD icon at the bottom right of the reply edit window).
You need to show some details of your attempt.
Well I can't seem to figure out the upload thing, maybe because its a mac. But I am certain that my equations are set up correctly, so if someone can just show me how to do the math. I've attempted it several times, but my professor hasn't showed us how to do all the different types of these equations.
If the image is in a file on your computer then the UPLOAD mechanism should be able to open a file list via your machine's operating system for selection. If not then perhaps the mechanism is blocked on your machine (security issue?). Otherwise, you should be able to cut and paste a "snipped" screen grab. Failing that, upload your image to a hosting side and paste a URL.
Regarding your equations, helpers won't do the math for you or show you step by step. You need to show what you've attempted in detail and they will point out errors, make suggestions, give hints and so on.
I attached the problem and my work. Where it says 3(4), that just means I multiplied equation 3 by 4, to add to the equation of 1+2
I'm having difficulty interpreting your handwritten work, but I can see that the results you're getting are not correct.
I've spotted one error in the first block of equations where you summed ##-6 I_3## and ##-16 I_3## and arrived at ##-24 I_3##, which is not right. I gave up after that.
You should endeavor to make the math you present more clear for others to read, preferably with some commentary to describe what you're doing at each step. Ideally you'd type in your equations so that they can be quoted in replies. LaTeX is a wonderful thing :smile:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
