Need help with Physics problem (momentum/collisions)
  • Thread starter Thread starter Engineering100
    Physics
The physics problem involves a 0.800 kg target moving at 3.0 m/s west and being struck by a 20.0 g arrow traveling at 260 m/s north, requiring the calculation of the final velocity post-collision. The conservation of momentum was applied correctly, yielding a final velocity of approximately 6.98 m/s at an angle of -65.2°, indicating a direction of 65° north of west. The discussion clarified that the negative angle represents a clockwise rotation, consistent with the defined coordinate system. Participants confirmed the correct interpretation of the angle as [W 65° N]. Overall, the solution was validated, with emphasis on understanding the directional conventions in physics.
Engineering100
A 0.800 kg target slides along the ice at 3.0 m/s [W], when it is hit by a 20.0 g arrow moving at 260 m/s [N], as part of a show. Find the final velocity of the target after the inelastic collision.
pi= pf
m1 v1i+ m2 v2i = (m1+ m2)vf
pythagorean theorem
v1f= ?
pix= pfx
m1 v1ix+ m2 v_2ix = (m1+ m2)vfx
(0.80)(-3.0)+0=(0.80+0.020) vfx
-2.4=(0.820)vfx
v_fx= -2.93 m/s
piy= pfy
m1 v1iy+ m2 v2iy = (m1+ m2)vfy
0+(0.02)(260)=(0.800+0.02) vfy
vfy=5.2/0.82=6.34 m/s
vf=√(-2.93)^2+(6.34)^2
vf=6.98 m/s
tanθ= -2.93/6.34
θ=25°
Since one of these values are negative, the angle is negative. Relatively speaking what would the angle be. also was this question in general answered correctly?
Yes you used the conservation of linear momentum properly, and successfully applied it to each coordinate individually.
The last step however is wrong, as the ratio should be:
<br /> \tan{\theta}=\frac{6.34}{-2.93}<br />
Which would give:
<br /> \theta=-65.2^\circ<br />The negative angle interpretation depends on how you defined your angles. In this case, the angles are defined in the sense such that \theta=0 along the "negative x-axis". Therefore a negative angle just represents clockwise rotation as opposed to counter-clockwise rotation. So it is traveling 65^\circ in the North-West direction. Make sense?
Normally, for example, \theta=45^\circ would be above the x-axis in the 1st quadrant, whereas \theta=-45^\circ would be below the x-axis in the 4th quadrant. In this case \theta=45^\circ would be in the 3rd quadrant below the x-axis and \theta=-45^\circ would be above the x-axis in the second quadrant.
This is due to the fact that the target is moving initially at an angle -180^\circ which is now taken as 0^\circ. Does this help?
yes thanks so much, great help
so would that be [W 65° N] or [N 25° W]?
Yes. You did it right, but why did you assume that the target was moving in the negative x direction to start with? There's nothing wrong with this, but I would have had it going in the + x direction (for some reason). Oh well. Potatoes, Potahtoes.
Chet
If I understand what you're saying correctly then it would be \text{[W } 65^\circ \text{ N]} (65 degrees North of West).
Also he did it that way because it specified that it was traveling West, and in introductory physics no one expects people to think like that probably.
electricspit said:
If I understand what you're saying correctly then it would be [W 65^\circ N] (65 degrees North of West).
Oh thanks. I didn't notice that [W].
Chet
yes, is [W 65∘ N] the correct angle?
