Need help with the reaction of neutrons and electrons
The reaction n + e- → Δ- + νe is theoretically possible under the weak interaction framework, as it conserves electrical charge, baryonic number, and angular momentum. While the reaction is not forbidden by conservation laws, its occurrence is significantly overshadowed by electromagnetic interactions, which dominate at the energy levels required for such collisions. The discussion highlights the similarities between this reaction and neutrino deep inelastic scattering processes, emphasizing the complexities involved in studying weak interactions in the presence of stronger electromagnetic forces.
  • Understanding of weak interactions in particle physics
  • Familiarity with conservation laws: charge, baryonic number, and angular momentum
  • Knowledge of neutrino deep inelastic scattering processes
  • Basic principles of electromagnetic interactions
  • Research the role of weak interactions in particle decay processes
  • Study the conservation laws in particle physics, focusing on angular momentum
  • Explore neutrino deep inelastic scattering and its implications in high-energy physics
  • Investigate the effects of electromagnetic interactions on weak processes
Physicists, researchers in particle physics, and students interested in the interactions between neutrons and electrons, particularly in high-energy environments.
Ruslan_Sharipov
Please let me know if the following reaction is possible for high energy electrons colliding with neutrons or neutron-rich nuclei:
<br /> n+e^{-}\to \Delta^{-}+\nu_e.\tag{1}<br />
If it is forbidden for some conservation law or for some other reason, please give me an explanation why. This reaction is analogous to the following ones, which are not forbidden:
<br /> \begin{gather}<br /> p+p\to D+e^{+}+\nu_e,\tag{2}\\<br /> n\to p+e^{-}+\bar\nu_e,\tag{3}\\<br /> p+e^{-}\to n+\nu_e.\tag{4}<br /> \end{gather}<br />
Is this homework?
No. Not a homework assignment. I am 57, too old for homework. I just want to discuss the reaction that I did not find anywhere on the Web.
Hello,
The interaction for case (1) is weak, because a charged lepton is turned into neutral lepton. So, the quantum numbers that must be conserved are electrical charge (ok), barionic number (ok), energy (ok?). Let's see angular momentum:
J(n) = 1/2
J(e-)=1/2
J(D-)=3/2
J(ne)=1/2
The combination of J_in = 1/2 x 1/2 = {1,0} (neutron + electron angular momentum)
The combination of J_out = 3/2 x 1/2 x L = {2,1,0} x L (D- + neutrino angular momentum
So if L = 3,2,1 or 0, the total angular momentum is conserved. Let's say angular momentum can be conserved.
If the reaction is mediated by the weak interaction, parity can be violated.
Maybe I am forgetting something, but I don't remember other quantum numbers that must be conserved for weak interactions.
From the experimental point of view, if neutrinos are involved in the reaction, the effects of electromagnetic force neutron-electron (which are orders of magnitude stronger) will disguise/shadow of the weak interactions; ie, the cross section of this reaction will be much smaller than other possible reactions (n+e- -> other things).
I hope it can help.
Regards,
ORF
If it is forbidden for some conservation law or for some other reason […]
[/tex]
Well it is not so absent from out there... it's very similar to the neutrino deep inelastic scattering processes, where the electron and neutrino are swapped (you shoot neutrinos and study the inner structure of the protons/neutrons). Of course the charges need readjustment.
ORF said:
energy (ok?)
You don't really have to think about the energy in MANY--->MANY processes in order to say if they are forbidden or not. Of course you might need a threshold to produce the final state particles but that doesn't forbid the interaction for you.
For neutrinos you have weak interactions only, so it is (comparatively) easy to study them. For electrons at the energies needed for this reaction you have the electromagnetic interaction which will completely dominate the collision processes.
Yup. Noting though that I was referring to whether the interaction is forbidden or not.
  • · Replies 17 ·
  • · Replies 29 ·
