Need info on 'Guard Pin' of ICs
  • Thread starter Thread starter pgokhale
    Pin
The discussion centers around the 'Guard pin' of integrated circuits (ICs), specifically the AD549 from Analog Devices. Participants explore the significance of this pin, its necessity, and its relationship to the concept of a 'guard ring'.
  • Exploratory, Technical explanation, Conceptual clarification
  • Some participants propose that guard pins are used to shield circuits from external fields.
  • One participant questions the necessity of the guard pin in low power scenarios, suggesting that negligible fields may reduce its importance.
  • Another participant describes the utility of an earthed guard pin in preventing stray feedback between input and output pins in high-gain amplifiers.
  • A further contribution explains that guard pins can help mitigate leakage currents by surrounding signal lines with a low impedance trace, which can be connected to the opamp case.
  • The AD549 datasheet is mentioned as a source of additional information regarding the guard pin's application.
Participants express varying views on the necessity and function of the guard pin, particularly in different operational contexts. There is no consensus on its importance in low power applications versus high-gain scenarios.
Some assumptions regarding the operational environment of the IC and the specific conditions under which the guard pin is beneficial remain unaddressed. The discussion does not resolve the implications of these factors.
pgokhale
Hi!
I came across an IC from Analog Devices - AD549, and happened to see a pin labelled as 'Guard pin'. It is being mentioned that the pin is connected to case.
I would like to understand more on the significance of this pin - its need and how to deal with it.
Also, is guard pin's need same as that of 'guard ring'?? Please advice.
Thanks in advance,
PGokhale.
As far as I know, those are used to shield the circuit (or pin, or connection, or whatever) from external fields.
Thank you mfb :) but if the op-amp is employed in low power scenario - employing only dc currents and voltages, the fields could be negligible. In this case how guard pin makes its usage prominent?
I can picture where an earthed guard pin would be useful as a separation between input pins and pins carrying the amplified output in a sensitive high-gain amplifier. You don't want stray feedback from output back to input.
The PCB trace that carries the input signal to your opamp isn't perfectly insulated, i.e. there's distributed resistance between it and adjacent traces, between it and the opamp package and so on. Nearby voltage gradients can thus cause current to flow in your signal line which might swamp out your input signal.
You can divert this leakage current away by surrounding your signal line with a low impedance trace that's biased at the same voltage as your signal line. The guard pin allows you to make the opamp case a part of this guard conductor.
The AD549 datasheet includes information about this under the heading "Circuit Board Notes".
@ NascentOxygen, milesyoung : thank you :) sounds good :)
