Need Mechanical Engineering Project
A college senior is seeking suggestions for a mechanical engineering project with a budget of $500 to $1,000, emphasizing the need to keep costs minimal. The project timeline is two months, and the student has faced rejection from their advisor regarding previous ideas. Other forum members inquire about the specific ideas that were dismissed to better understand the constraints. The discussion highlights the importance of innovative yet feasible project proposals within the given budget and timeframe. Participants aim to provide constructive suggestions to help the student succeed.
furena01
Hey guys, I am looking for an engineering project that has mechanical components. I have 2 months for the projects. I am currently a college senior. I have some ideas but have been shut down by the advisor. Any ideas would be appreciated. The budget for the group is between 500-1000 dollars but should be kept as minimal as possible.
Thanks.
What were your ideas that got shot down?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
