Need some help on air pressure through a manifold and optimal leak/pressure rate
The discussion focuses on optimizing air pressure through a custom manifold for an aquarium pump system. The user seeks to determine the ideal orifice size for two air rails to maintain maximum pressure during the 7-second off phase of the pump cycle. The total volume of the manifold and tubing is calculated to be 2.9828 cubic inches, with specific pump performance metrics provided. Despite the request for assistance, the user expresses frustration at the lack of responses and indicates a willingness to experiment with different orifice sizes. The conversation highlights the challenge of achieving consistent pressure management in small-scale pneumatic systems.
pityocamptes
I have a small pump system for an aquarium, and have decided to build a small manifold. The total volume of the manifold and the tubing is 2.9828 cu inches. Here is my pump specs:
Inflation time < 8s (from 0-200 mmHg in a 100cc tank)
Air flow > 70mL/min
Max pressure > 360mmHg
Leakage max 36mmHg/15sec from 300mmHg at 70cc tank
Pump time - 7sec on / 7sec off
From the pump is a 3/16" x 12" tube (volume = .3311 cubic inches) which attaches to a small cylindrical manifold (1"x3" - volume = 2.3571 cubic inches) that has two air rails (each air rail (1/4" x 3" -volume = .2946 cubic inches). Total volume should be 2.9828 cubic inches.
I was hoping to see if someone could figure out how big of an orifice I would need on each rail for maximum pressure, within the 7 seconds on, 7 seconds off (basically optimal orifice pressure and size where manifold drops stays at a constant positive pressure at the end of the 7 second off phase wherein the 7 seconds on phase starts to pump and build pressure. Any help on this would be appreciated. Thanks.
Anyone? Bump...
No one? Thats odd. I guess than, I will just have to experiment with different orifice sizes to get the best result, was trying to avoid this and wanted to see if a mathematical solution existed for this problem.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
