How Many Ladies Had All Four Items at the Church Fete?
  • Thread starter Thread starter ilvpat
    Set
Out of 100 ladies at the church fete, the discussion revolves around determining how many had all four items: a white handbag, black shoes, an umbrella, and a ring. The analysis suggests that while the problem seems under-determined, it can be approached by calculating lower bounds. By considering overlaps among the items, it is concluded that at least 10 ladies must have had all four items, with a maximum potential of 60. A simplified version of the problem is recommended for better understanding, emphasizing the importance of interpreting the question correctly. The discussion highlights the significance of analyzing complements to arrive at the solution.
ilvpat
Q:
Out of 100 ladies attending the church fete, 85 had a white handbag; 75 had black shoes; 60 carried an umbrella; 90 wore a ring, How many ladies must have had all four items?
I feel like the problem is under-determined. But if anybody can explain it to me it would be great. Thank you very much.
Mathematics news on Phys.org
It certainly looks that way, but we can reinterpret "must have had" as a lower bound, that is, we are interested in finding out what is the least number of ladies that had to have all for items!
Now, consider the ladies with rings, and those with handbags.
At least 75 of them must have had both (why?)
Now, furthermore consider the R&H ladies (those with rings AND handbg), and those with black shoes (S). Now, of the S population, only 25 max could not be wearing both R and H, since the 100 ladies can be divided into those having both R and H (at least 75) and those not having both (at most 25).
Thus, of the S ladies, at least 50 of them are R&H&S ladies.
Finally, only max 50 of the umbrella ladies U could not be R&H&S ladies; hence, at least 10 U's are also R&H&S ladies.
Thus, at least 10 ladies had all four objects, up to a maximum of 60.
Welcome to physicsforums ilvpat,
my advice is to try a simplified version of the problem.
Out of 100 ladies, 85 have a white handbag, 75 have black shoes.
How many ladies must have both items?
I think if you can solve this simplified problem, you can also
solve the original one.
I see now. The way I interpreted the problem leads me to the wrong direction. I was looking for a unique solution rather than a bound. Thanks guys!
It might be simpler to look at complements:
15 are w/o a white handbag
25 are w/o black shoes
40 w/o umbrella
10 w/o ring
That's 90 without something, leaving 10 with everything.
(what happened? We maximized the number with 3 of the 4)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
14K
13K
14K
