Mastering the MacLaurin Series and Radius of Convergence for f(x) = ln(1-x)
  • Thread starter Thread starter jkh4
jkh4
Consider the function
f(x) = ln(1-x)
a) compute the MacLaurin series of f(x) (ie: the Taylor series of f(x) around x=0)
b) Compute the radius of convergence and determine the interval of convergence of the series in a)
c) Determine the Taylor series of f'(x) around x=0. Can you do so without using a)?
d) How would you have computed part a) if you had first done part c)?
Thank you!
Hi,
You need to show your work in order to get help. Forum guidelines.
Someone posted this exact same question in the Calculus and Analysis forum.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
