How Many Bolts Are Needed for PVC Flanges on a Filter Column?
  • Thread starter Thread starter Bashir2008
    Bolts
For a filter column with a 315mm outside diameter and 3m length, standard PVC flanges are recommended due to the low pressure involved. The number and size of bolts depend on the specific design and load requirements, but using standard bolts for PVC flanges is advisable. It's important to include gaskets for a proper seal, especially with wire mesh between flanges. If custom design is pursued, understanding the expected loads and pressures is crucial for accurate analysis. Proper selection of materials and components will ensure the integrity of the filter column assembly.
Bashir2008
Hello everyone.
I really in dire need of your help as i am not a mechanical engineer, so at this stage i am busy finding out the right design of PVC flanges for a filter column.
But the thing is
How to choose the right bolts ? i mean how many bolts should i have for my flanges and what size of bolts..
What i can tell u is my filter column is 315mm outside diameter and 3 m length and the filter is of 3 sections and i need to connect these sections by grey PVC flanges..and i will put a wire mesh between the flanges
by the way, the filter column is a clear PVC
So please how can i start with ?
Try to help me
Best regards
Since it's PVC, it has to be relatively low pressure. Just use standard PVC flanges and the respective bolts and gaskets. That would be the easiest. If you want to design your own, you need to know the expected loads and pressures before starting an analysis.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
