Need to buy High temp. vessel
  • Thread starter Gnomie27
  • Tags
    Vessel
In summary, a high temperature vessel is a container or tank specifically designed to withstand high temperatures without deforming or breaking. They are typically made of materials such as stainless steel or titanium and are used in industrial and scientific settings for processes that require extreme heat. When working with high temperature vessels, safety precautions must be followed, and the right vessel should be chosen based on factors such as temperature range and intended use. High temperature vessels can be purchased from specialized suppliers or manufacturers, as well as online marketplaces and trade shows.
Gnomie27
Hi, I was wondering if anyone knew where I could buy a pressure vessel that meets the following specifications:
min. pressure: 2,000 psi
max temp.: at least 800°C
volume: around 80-100 mL
I've been searching for around month now with little success... I could really use some help, thanks!
here is a picture of the type of reactor I need:
What is a high temperature vessel?
A high temperature vessel is a type of container or tank that is designed to withstand high temperatures without deforming or breaking. It is commonly used in industrial and scientific settings for processes that require high temperatures, such as chemical reactions or material testing.
What materials are high temperature vessels made of?
High temperature vessels are typically made of materials that can withstand extreme heat, such as stainless steel, titanium, or other high-strength alloys. The specific material used will depend on the desired temperature range and the type of substances that will be contained in the vessel.
What are the safety considerations when using a high temperature vessel?
When working with high temperature vessels, it is important to follow proper safety precautions. This may include wearing protective gear, ensuring proper ventilation, and using the correct equipment for handling and monitoring the vessel. It is also important to be aware of the potential hazards associated with high temperatures, such as burns and chemical reactions.
How do I choose the right high temperature vessel for my needs?
Choosing the right high temperature vessel will depend on several factors, including the desired temperature range, the materials being used, and the intended use of the vessel. It is important to consult with a specialist or supplier to determine the best option for your specific needs.
Where can I buy a high temperature vessel?
High temperature vessels can be purchased from specialized suppliers or manufacturers. It is important to research and compare options to ensure that the vessel meets your requirements and is of high quality. Online marketplaces and trade shows may also be a resource for purchasing high temperature vessels.
  • Mechanical Engineering
