Net force from a varying speed non-uniform rotating wheel?
The discussion centers on the concept of net force in a non-uniform rotating wheel, questioning whether varying mass distribution and speed could produce a directional net force. It is clarified that while a force of v^2/r is generated, it does not result in a net directional force due to cancellation. The conversation touches on the implications of shifting the center of mass and the complexities of momentum and energy conservation, ultimately dismissing the idea as akin to a Reactionless Drive, which is not accepted in conventional physics. The thread concludes with a reminder that energy conservation is a fundamental principle that would be violated if such mechanisms were possible. Overall, the feasibility of achieving a net force through these methods is rejected.
NotASmurf
If we have a circle rotating then a force v^2/r is produced but no net directional force exists as it cancels.
But if the wheel was not uniform in mass ie not rotating around its centre of mass AND the speed changes over time as a function of the "wheel"'s rotation angle could a net force be produced in a direction of choice? If not then could it be achieved by doing the above AND varying the centre of mass?
That is not a force, it is an acceleration. More precisely, it is the magnitude of the acceleration of an object rotating with the disk at radius r.
If the center of mass is not at the rotation axis you need a time-dependent net force on the object to have it rotating around its off-center rotation axis, but integrated over one rotation the average force is zero.
Accelerating the system doesn't change anything, shifting masses around just makes the calculations more complicated, and overall momentum and energy are conserved exactly.
Likes NotASmurf
It sounds like you are trying to discuss a Reactionless Drive mechanism, which along with PMMs and Over-Unity mechanisms, we do not take the time to discuss. Is that what you are asking about?
https://en.wikipedia.org/wiki/Reactionless_drive
I know this post seems stupid, only asking because our physics TA (in honours and spends too much of his clean energy optimization funding on rent) said that this was "an active area of research".
Oh, is the reason this isn't possible because (sorry for no latex, my keyboard is broken, on screen keyboard is effort and latex takes more typing):
e=.5mv^2, f=ma
f=m. ∂/∂t [2e/m]^0.5
for a net force we need:
Σf=0
to not be true.
thus
Σf≠0 ⇒ f≠[2]^0.5 * ∂/∂t * [m^-0.5 * e^0.5 * m] ⇒ 0 ≠ Σ(e^.5)(m^[-3/2]) ⇒Σe≠0
So if he was right energy wouldn't be conserved?
As I said, we don't waste time discussing such things here. Thread is closed.
EDIT / ADD:
There are many reasons it cannot work, energy conservation could be one of them. Please follow the links in the Wikipedia article for more reasons it cannot work.
Likes NotASmurf
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
