Calculate Satellite Velocity in Stable Orbit
To calculate the velocity of a satellite in a stable circular orbit at a height of 5200 km, the formula for centripetal acceleration, Ac = (V^2)/r, is applicable. The discussion emphasizes the need to determine the gravitational force acting on the satellite to fully understand the dynamics involved. Participants confirm that using this formula is correct for calculating the satellite's acceleration. The conversation highlights the importance of identifying the necessary forces to maintain the satellite's orbit. Understanding these principles is crucial for solving orbital mechanics problems.
smaxemow
Q.Calculate the velocity of a satellite moving in a stable circular orbit around the Earth at a height of 5200km.
A. I wasn't sure which formula to use on this problem is it Ac=(V^2)/r
Well I don't know what other information you have
But what provides the centripetal force needed to keep the satellite in the orbit?
Welcome to PF!
Hi smaxemow ! Welcome to PF! :smile:
Simple answer: yes. :smile:
That gives you the acceleration.
And now you need to know the force … :smile:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
