pipjordan
- 2
So I have the mass, volume, and the density of the gas inside it...how do i work out the net force?
Is it to do with working out weight and then viscous drag?
To calculate the net force of a balloon, you need to first determine the weight of the balloon and the amount of air inside it. Then, you can use the formula Fnet = Fbuoyancy - Fgravity, where Fbuoyancy is the force of buoyancy acting on the balloon and Fgravity is the force of gravity pulling the balloon down. The net force will be the difference between these two forces.
The net force of a balloon is affected by the weight of the balloon and the amount of air inside it. Additionally, external factors such as temperature, pressure, and altitude can also impact the net force of a balloon.
Yes, the net force of a balloon can be negative. This means that the force of gravity pulling the balloon down is greater than the force of buoyancy pushing it up, causing the balloon to sink.
As a balloon rises in altitude, the net force will decrease due to the decrease in air pressure and density. This will cause the balloon to expand and become less dense, resulting in a decrease in the force of gravity and an increase in the force of buoyancy.
The net force of a balloon can be used in weather forecasting, as changes in altitude and temperature affect the net force and can indicate changes in air pressure and density. It can also be used in designing and testing hot air balloons and other aircraft, as understanding the net force is crucial in achieving lift and stability.
