Net torque, electric dipole confusion
A net torque on an electric dipole in a uniform electric field is not zero because, although the forces on each charge cancel out, they create a rotational effect. Each pole experiences an opposite force that causes them to rotate in the same direction rather than counterclockwise. This results in a net torque that is non-zero. The confusion arises from misunderstanding the distinction between net force and net torque. Understanding these concepts is crucial for analyzing dipole behavior in electric fields.
Bengo
Hello all,
I am so confused on why a net torque on a dipole in a uniform electric field would not be equal to zero. Wouldn't one end rotate clockwise, the other counterclockwise and cancel out to zero?
Thanks.
Since each pole has an opposite charge and thus feels an opposite force, each tends to turn in the same direction. The net force cancels, but the torque does not.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
