Neutron Stars and unbinding energy
The discussion centers on calculating the velocity required to unbind two neutron stars through a collision, using gravitational binding energy equations. The gravitational binding energy, Ug, is approximated as GM^2/R, while the kinetic energy from the stars' collision must equal this binding energy to achieve unbinding. Participants note the assumption that only gravitational forces are at play, disregarding other inter-atomic forces, which is not realistic. The binding energy formula is mentioned as 3GM^2/5r, highlighting the complexity of the problem. Ultimately, the challenge lies in equating the kinetic energy of the neutron stars to their gravitational binding energy to determine the necessary collision velocity.
Minihoudini
The Gravitational binding energy of an object consisting of loose material, held together by gravity alone, is the amount of energy required to pull all of the material apart, to infinity. the gravitational binding energy Ug is roughly given by GM^2/R. how fast do you have to smash two neutron stars to get sufficient energy to unbind them?
I honestly don't know where to start. I believe my teacher is asking for the velocity and then get the energy? also what formula should I use?
im thinking we use Ug=Gm^2/R and use Ug= -GMm/r and have r= Tv/2pi
The energy needed to overcome the gravitational forces keeping the neutron star matter together would have to come from the kinetic energy of the stars before collision. When they collide, that energy would have to be converted into kinetic energy of the individual molecules. Although this is thermodynamically not possible, I think that the question assumes that this is the case.
So equate the kinetic energy of two neutron stars of mass M as they are about to collide to the total gravitational binding energy of the two stars.
The question assumes that there are no inter-atomic forces other than gravity, which is not realistic.
Incidentally, the binding energy is 3GM^2/5r. See: http://en.wikipedia.org/wiki/Gravitational_binding_energy
AM
