Physics Assignment Help: Finding the Best Boat Form for Optimal Speed!
  • Thread starter Thread starter Bafsemann
The discussion centers on a physics assignment requiring students to determine the optimal boat shape for speed under a specific force. Participants suggest using graphs of position versus time to derive a general equation, emphasizing the importance of drag force equations like F = kv or F = kv^2. Key insights include the significance of hull design and the need for constant velocity during experiments to measure force accurately. The original poster is experimenting with various boat shapes, including a box design, to observe differences in speed. Overall, the conversation highlights the complexities of hydrodynamics and the experimental approach to understanding boat performance.
Bafsemann
Hello all, this is my first post on this forum having read it from time to time when in need of help for my physics :smile:
So to the point. My physics teacher is meeean, he gave us this huge assignment just before the summer break just so that we wouldn't be given the opportunity to slack of :mad: !
We are to find the best suitable simple (not to extreme) boat form that has the best speed while applying a certain amount of force to it.. I thought the question was kind of vague, but he insisted on us solving it... So we got a tub and some measuring devices, and substance to make boat shapes out of. Sooooo my question is basically, if i have some graphs showing the position vs time of the boat at different drag force and different weights of the boat, how do i find a general equation for the graph? I have tried best fit lines, and arrived at some equations.. but.. argh... I'm just stuck.. completely stuck...sick of school and longing for that long summer break, so my brain doesn't really function that well..
Any help would be greatly and deeply appreaciated!
Student in trouble! :eek:
Drag force is usually in either F = kv or F = kv^2 form.
You have the graph. The curve will be a straight line, try to find different values for k. V is velocity.
Hydrodynamics is a tough topic. People are still working on boat hull design to this day, trying to improve it.
Two things that you should keep in mind when working things out are:
Water doesn't like to move rapidly, so the less, and the more slowly you move it, the better you'll end up doing.
And, the tail end of the boat is just as important as the front end.
Thanks for the help guys. Been playing around with the different graphs now, and realiced the difference between the 2 hull shapes (i made 2 hull shapes to check if the difference between the 2) wasn't there .. so I'm going to have to try to perform some tests with boats with other shapes, and which are shaped in the back as well. The really hard part is to be able to calculate why the different shapes travel at different velocities.. ah well, I'm going to have loads of fun this weekend! :cry:
How are you setting up your experiment?
I would be inclined to try to get constant velocity movement, and measure force. Using constant force is tricky.
Also, you might want to try deliberately 'stupid' designs to make sure things are working.
Well don't i get a constant force when i drop a weight? I have connected the weight to a system so that it pulls horizontally on the boat while being dropped, wouldn't that be a constant force?
And I am trying with many shapes now, starting of with a normal box, to see the difference in the shapes compared to the box.. I might be getting somewhere for once :smile:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
