Newtonian gravity theory and energy
The discussion centers on calculating the impact speed of a 1.0 kg object released from 500 km above the Earth, using energy conservation principles. The initial calculation yielded an incorrect speed of 10,776 m/s, while the correct answer is 3.02 km/s. The error stemmed from neglecting the gravitational potential energy (GPE) at the Earth's surface, as the GPE is defined to be zero at infinity, not at the surface. Participants clarified that the change in GPE between the two positions must be considered to accurately determine the kinetic energy. The original poster acknowledged the mistake and expressed the need for further review of the topic.
Lord Anoobis
A 1.0kg object is released form rest 500km above the earth. What is its impact speed as it hits the ground? Ignore air resistance.
##U_g = \frac{GmM_e}{r}##
##K = \frac{1}{2}mv^2##
## \Delta U = - \Delta K##
Using energy conservation I arrived at
##\frac{GmM_e}{r} = \frac{1}{2}mv^2##, then ##v = sqrt{\frac{2GM_e}{r}}##
Plugging in values, ##v = \sqrt{\frac{2(6.67\times10^{-11})(5.98\times10^{24})}{(6.37\times10^6 +5.00\times10^5)}} = 10776 m/s##, never mind the significant figures.
This is rather far from the correct answer though, which is 3.02km/s.
(According to your equation for the gravitational potential energy) is the GPE zero at the surface of Earth?
P.S.
There should be a negative sign on Ug
Forgot to put the negative sign in there. By the look of it the GPE is zero at the centre of the earth, which accounts for the excess energy, correct?
Solve for v
It has nothing to do with the center of the Earth.
You have two positions, 500km above the surface, and at the surface. The change in the GPE between these two positions is equal to the change in kinetic energy. Your calculation neglected the GPE at the surface of Earth.
(Your equation for the GPE takes the zero-potential to be at infinity, not at the surface.)
Engineer at UIC said:
Solve for v
True. I got that mixed up. Problem solved and thanks for the input. I feel I need to have another closer look at this section though.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
