What Do Newton's Laws Say About the Forces on a Painter on a Leaning Ladder?
  • Thread starter Thread starter mybrohshi5
    Laws
The discussion evaluates the forces acting on a painter at rest on a leaning ladder using Newton's laws. The painter argues that the force from the ladder equals the gravitational force from the Earth, which is supported by Newton's first law, indicating no net force and thus no acceleration. However, the third law is not applicable in this context since it deals with action-reaction pairs between different bodies, while the forces in question are not acting on the same body. The analogy of a skydiver illustrates that equal and opposite forces do not prevent acceleration, emphasizing that the first law is more relevant here. Ultimately, the conversation clarifies the distinction between different types of forces and their implications for motion.
mybrohshi5
A painter is statically at rest on a ladder leaning against a wall. The painter argues that the force on the painter by the ladder must be equal and opposite to the force of gravity on the painter by the Earth. Evaluate the painters argument.
the answer is: Newton's first law can be used to demonstrate the the painter is correct.
I agree with this but i also believe it should be Newtons third law too because that law states that for every action there is an equal and opposite reaction right?
Is Newtons third law not used to to demonstrate that the painter is correct because the question states "the force on the painter by the ladder must be equal and opposite to the force of gravity on the painter by the earth." If it would have stated "the force on the painter by the ladder must be equal and opposite to the force on the ladder by the painter." then would Newtons third law be used to demonstrate he is correct?
But the thing is i thought the force on the ladder by the painter is the force of gravity on the painter by the earth, and that is why i think Newtons third law should be used as well.
Thanks for any input on this :)
No. Newton's third law is not adequate. Think of it in terms of skydiver who has just jumped out of a plane. The gravitational force exerted by the Earth on the person is equal and opposite to the gravitational force exerted by the person on the Earth. Yet the person accelerates downward. Why is that?
I am not sure exactly why [ but i would like to know ;) ] but i think i get what you are trying to get at. The first law explains he is correct because the net force on him is zero which means his motion won't change (he is statically at rest).
The third law doesn't explain he is correct because (like the skydiver) even though there may be forces equal and opposite in direction, the body can still be accelerating (because one force is larger than the other?)
The third law, along with Newton's universal law of gravitation, very clearly says that the force exerted by the Earth on the person is equal and opposite to the force exerted by the person on the Earth.
Suppose the skydiver steps out of a hovering helicopter rather than an airplane. At the moment the skydiver jumps out the only force acting on the skydiver is gravity. The skydiver falls Earthward. That the skydiver exerts an equal but opposite force on the Earth does not affect the skydiver's acceleration with respect to an inertial frame. Instead, it makes the Earth accelerate (by a tiny, immeasurable amount) toward the skydiver.
As soon as the skydiver picks up some speed the skydiver will start meeting some air resistance. This drag force is directed upward and grows as the skydiver's downward velocity increases. Eventually the skydiver will reach what is called terminal velocity; the velocity no longer increases. Again using Newton's first law this can only mean one thing: that the upward drag force is exactly canceling the downward gravitational force.
However, that this drag force is equal but opposite to the gravitational force does not mean that the drag and gravitational force are third law pairs. For one thing, the drag force is not always equal but opposite to the gravitational force; drag is zero at the instant the skydiver jumps out of the helicopter. For another thing, third law pairs always acts on two different bodies. In the case of gravitation, the two bodies are the Earth and the skydiver. For drag, it is the atmosphere and the skydiver. That the air pushes the skydiver upwards means that the skydiver is pulling the air around him downward.
What does Newton's second law tell you about the sum of all the forces involved?
Is the painter accelerating? If not, why not?
[Edit: this was posted as a hint, btw. :wink:]
