Newtons cradle, conservation of momentum
Momentum in a Newton's cradle is conserved in the horizontal direction, but the vertical momentum is affected by gravity, which complicates the conservation analysis. When a ball is raised and released, the initial and final momenta of the system can be considered zero, indicating that momentum is conserved overall. The cradle itself is not a closed system if external forces, like gravity, are considered. To fully understand the momentum conservation, one should analyze the forces acting on the balls and the cradle through free-body diagrams. Overall, while energy and momentum are ideally conserved, real-world factors like gravity can lead to some loss of momentum in the system.
Bengo
I don't understand how momentum is conserved in Newtons cradle. If I look at the component vectors for the initial ball on the left that I raise, one component points down and one points to the right but then looking at the vector components on the ball that moves on the right end, it has one component up and one component to the right. The horizontal components are conserved but the vertical components aren't.
M1v1i + m2v2i = m1v1f + m2v2f for x and y components
I think the vertical component of momentum is not conserved due to gravity?
You have used: ##\vec p=m\vec v##
... you have correctly noticed that momentum is a vector, but you seem to have forgotten that the initial and final momenta in your description are both zero (the balls start and end with v=0) - which conserves momentum over the entire journey.
Note: conservation laws only apply to closed systems ... you have concentrated on the balls.
Is the ball a closed system? Is the cradle a closed system?
When the ball is released, you can draw a free-body diagram to understand it's motion.
What is the total force on the ball? What does this do to the ball's momentum?
Are there any external forces acting on the frame of the cradle?
At the instant the ball impacts the others, what direction is it's momentum?
At the instant the right-hand ball starts to move, what direction is it's momentum?
... you can then draw a free-body diagram to understand it's subsequent motion.
Likes 1 person
Try looking up impulse on google
Momentum and energy would ideally be conserved, but even the idealized reaction for Newton's cradle is that the pack of balls at rest will shift on each collision, and since they are supported by finite length lines to the frame, gravity somewhat opposes the pack shift, so some momentum is lost unless you include the frame and the Earth that the frame rests on as parts of a closed system. Here's a link to a good article about Newton's cradle:
https://www.lhup.edu/~dsimanek/scenario/cradle.htm
Likes 1 person
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
